02 Simulator
Old Mar 2, 2004 | 08:51 AM
dawrenn's Avatar
dawrenn
Default 02 Simulator
I have a High Flow Converter on my car and the MIL came on. I know the reason it came on is that I intsalled the converter. I was wondering if my car will get messed up by driving with it like that? I know that if I don't get it fixed then I will not know if the MIL comes on for any other reason. I was wondering if and O2 Simulator is worth $50?
Old Mar 2, 2004 | 09:19 AM
shivers's Avatar
shivers
Moderator Alumni
The CEL from the secondary o2 sensor won't cause any damage or throw the car into limp mode. If you can tolerate the light, there's no reason to get a eliminator kit.
2005 s2000
Old Mar 2, 2004 | 02:05 PM
bustah49's Avatar
bustah49
Mr. Motorhead
http://bigjoshracing.com/store/shop/index.html
it is called mil eliminator
Old Mar 2, 2004 | 07:20 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
The secondary O2 won't throw the ECU into limp mode? My friend had a '97 (or '98, I forget) ITR and he put a test pipe on and got the CEL. Everytime you were around his car you could smell fuel and it seems sluggish. He ended up getting a custom testpipe made with a welded on pipe the O2 sensor screwed into. It wasn't actually in the exhuast flow but strapped to the pipe and thermal wrapped to keep it up to temp and the CEL went away. His car run 13.9 with just an I/H/E and some good driving. He's running a Hondata system with a turbo now.
Old Mar 3, 2004 | 05:33 AM
shivers's Avatar
shivers
Moderator Alumni
The car shouldn't go into limp mode, but there's always exceptions. Test pipes definitely make the car smell awful, but there's no real way around that since you're getting raw exhaust that hasn't been cleaned up by the cat. There are exhaust components that have a smaller inlet that the secondary o2 sensor fits in to more or less "trick" it into thinking that a cat is present. A friend of mine has a test pipe from Buscher racing on his EVO with this feature. It's pretty neat, but I don't recall seeing anything like that for a Honda/Acura, but whatever your friend did worked out fine.
2005 s2000
dawrenn
92+ Civic/EL & Del Sol
8
Aug 26, 2003 09:37 AM
BrandonClaps
8
Aug 21, 2003 07:27 PM
Fujiwara Takumi
Aug 21, 2003 04:07 PM
clickwir
Jul 11, 2003 02:28 PM
