F**king Problems Man !!!!!!!!!!!!
Old Feb 10, 2004 | 04:58 PM
honura's Avatar
honura
Seni
Default F**king Problems Man !!!!!!!!!!!!
This Dahm coupe . Feel like taking a 9mm and dropping slugs into this shit !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :awais: Well we swapped the motor into the dx Coupe "D15B" stock ECU , harness , ext . Well the car did not wanna start at first . So we sprayed some starter fluid into the intake to see if it would start . Ehhh kinda wanted to . So I took off the injectors and looked at them and they where SHOT ! So we replaced that and car started up np . Drove it around the block and that was it car died . I changed the distro , plugs , cap+rotor , and sparkplugs . NOTHING ! Im thinking it might be a Fuel problem but it's spraying gas if you take the hose off . Anyone can help ? TIA
Old Feb 10, 2004 | 10:38 PM
ragerized's Avatar
ragerized
dc4 ownerages
check the fuel rail, injectors could be fawked again.
just plug the hose dude.
Old Feb 10, 2004 | 10:39 PM
honura's Avatar
honura
Seni
Nah the hose is fine . When I removed it to check it thats when I knew it was good cause it was spraying .
Old Feb 11, 2004 | 05:12 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
does it have compression? Are you sure you're getting spark?
4 things you need for a running engine:
Fuel
Air
Compression
Spark
Timing comes after it's running.
Old Feb 11, 2004 | 05:35 AM
honura's Avatar
honura
Seni
Well How do you tell it has compression ? I mean the car wants to start when you spray starter fluid and it did turn on without it and stayed on for about a good 3-5 mins . Also I don't know if the distro is giving sparks . If it's not how will I go about trouble shooting that problem ? Thanks . I mean I can install a motor NP just not the best in trouble shooting .
Old Feb 11, 2004 | 06:25 AM
Wharbone's Avatar
Wharbone
maybe you need a new ignitor
Old Feb 11, 2004 | 10:11 AM
honura's Avatar
honura
Seni
Yeah thats been changed as well ! F**king car just won't start .
Old Feb 11, 2004 | 11:27 AM
Wharbone's Avatar
Wharbone
Are you throwing any codes? How is your fuel pump, and what fuel pump are you using? Could be your ecu maybe?
Old Feb 11, 2004 | 12:13 PM
honura's Avatar
honura
Seni
Changed ECU fuel pump is good cause it's working ! f**k im pissed .
Old Feb 11, 2004 | 01:20 PM
Wharbone's Avatar
Wharbone
Is your CEL on? Are you getting spark? Any codes?
