struts
Old Feb 1, 2004 | 09:10 PM
Darkspaces's Avatar
Darkspaces
Default struts
someone told me i had an adjustable supension system that i could lower it and raise it?? how would i go about doing that raising it back up?? does anybody know?? it is on a 94 honda civic.
Thanks,
Kevin
Old Feb 2, 2004 | 08:43 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
well, if you have adjustable coilovers you can
Old Feb 2, 2004 | 09:10 AM
Darkspaces's Avatar
Darkspaces
it looks like i do, they are threaded at the bottom it looks like one big bolt
Old Feb 2, 2004 | 09:25 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
first..find out what kind of sleeved coilover setup you have.
most applications either uses two fork type keys or an allen wrench to adjust height.
Old Feb 2, 2004 | 10:22 AM
Nelson's Avatar
Nelson
Administrator
Would you happen to know at least what brand of shocks/springs you have on your car?
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Feb 2, 2004 | 10:42 AM
PDiggityDogg
all ya gotta do is turn the spring base so its higher up on the threaded body
you should have a special too to do it, that kinda looks like a outward-bent hook
If you dont, you can use vice-grips...
Old Feb 2, 2004 | 11:23 AM
Darkspaces's Avatar
Darkspaces
ok i just took my front two tires off, there is a blue spring and at the bottom something that looks like a bolt is that what i turn??? and is it the same with the back???
Old Feb 2, 2004 | 01:34 PM
PDiggityDogg
it will look like a nut rather than a bolt
the spring sits on the nut
turn that
===||NNN}
Ok, heres a cheap quick diagram:
See the ==='s are the shock body
the || are the spring seats/'nuts' that are threaded onto the shock
NNN is the spring
} is the strut cap
turn the ||'s (spring seats) so the spring compresses and raises the vehicle
Old Feb 2, 2004 | 01:39 PM
Darkspaces's Avatar
Darkspaces
turn that
===||NNN}
NNN is the spring
} is the strut cap
cool that makes since, i can just use a pair of visegrips for that? thanks again man.
Old Feb 2, 2004 | 01:53 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
===||NNN}
:lmao:
