timing help !
Old Jan 27, 2004 | 07:44 PM
honura's Avatar
honura
Seni
Default timing help !
can someone help me out ! I need to time a cx motor and I wanna know the point . I think thats what it's called ! Picture or something thanks guys !
Old Jan 27, 2004 | 07:52 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
loosen the 3 distrib. bolts (12mm) - have 1 almost tight so you can tighten it real quickly.
Put a paperclip into the 2 prong clip by the ECU (like you're going to check a code). Connect the timing gun and then start the car. Point the gun down the timing belt cover and lineup the timing mark on the cam cover with the red mark on the crank pulley (it's the one in the middle of the 3 marks).
Turn the distributor one way or the other unitl that mark is lined up correctly. When it is, tighten up that one bolt you left kinda tight. Now you can put everything down and tighten the others up when your hands aren't full.
hih
Old Jan 27, 2004 | 08:03 PM
honura's Avatar
honura
Seni
Sorry I might not have made myself clear ! There is no belt on there now ! and I wanna give the motor to the person allready timed up ! The distro has never moved it's still there . And I don't have a gun . Someone told me all I have to do is line up the marks and thats it ! Maybe he was wrong ?
Old Jan 27, 2004 | 09:00 PM
metalman's Avatar
metalman
with the red mark? i thought it was the white mark you line it up with.
Old Jan 27, 2004 | 09:01 PM
honura's Avatar
honura
Seni
I don't know ! I need to find out how thats all !
Old Jan 27, 2004 | 09:13 PM
westcoaststyle
There's no timing belt on there now? You're wondering how to put the timing belt on correctly?
Metalman: I'm 90% sure it's red. The white mark is the TDC mark, not the timing mark.
Old Jan 27, 2004 | 09:16 PM
honura's Avatar
honura
Seni
I know how to put it on but someone told me all I have to do is line it up and thats it !
Old Jan 28, 2004 | 04:57 AM
westcoaststyle
Well, to put it on correctly you have to line it up, but that does not set the timing. The timing is based on the rotation degree from the center axis of the distributor. You will need a timing gun to accomplish this.
Old Jan 28, 2004 | 07:15 AM
metalman's Avatar
metalman
yup, you're right, the center red mark. white is tdc.
Tr0LL
Engine Swaps, Tech & Tuning
13
Jul 6, 2003 03:48 PM
NeverBX
11
Jun 23, 2003 06:42 PM
JiggaFan
4
Feb 22, 2003 08:55 PM
98CoupeV6
Do It Yourself
Jan 17, 2003 04:52 PM
thx247
2
Jan 9, 2003 07:39 PM
