when you do, look into g/c shocks. They can custom valve a shock to your exact specs, and take into consideration your travel range. I believe they are both compression AND rebound adjustable
GC said i can do it either way. I want to do the koni to a 2 way adjustment with a re-valve. The re-valve on the koni are $250 front and $300 rear each. The advanced design GC struts are $399 each. Already have a re-valveable strut so i might as well use it.
