skunk2 coilovers
Originally Posted by lkailburn
how do skunk2 compare to ground control?
when I had skunk2's on my accord, they were ****ing horrible. They were SOOO damn bouncy. I don't know if they are any different for the civics, but I seriously wouldn't recommend them to anybody.
i've got a set of AGX's and a cheaper set of coilovers. i'm only planning on doing a 1.7" or 1.8" drop all around and doing the rear camber washer trick. after getting an alignment i should be good for tire ware correct?
Originally Posted by ZimZimma13
If you're dropping 3" you want to get a camber kit too like Ingalls ( :thumbup: ) or Progress are both good. otherwise your tires are ****ed. Yeah you want an alignment too.
h:Not a great idea...
I run Skunk2 every day... I have nothing but good things to day.
Originally Posted by westcoaststyle
Progress isn't adjustable.
h:
Not a great idea...
Westcoast- have you run GC before?? Just order some for my coupe 450 pair and 500 pair. Did 7" so i could swap them front to rear or so on. What lenght skunk's are you running.
Hey how is it going everybody I have a couple questions. By the way I want to lower my ride as low as to close the gap.
Are coilovers recommended to new generations?
Should I put lowering springs or coilover for my 04?
Are Eibach lowering springs good? Why? What brand is better?
How much should I pay for coilovers installed? Lowering Springs installed?
Thanks everybody......
