Drop some I-vtec knowledge
Old Jan 23, 2004 | 01:05 PM
YeaItsAFourDoor's Avatar
YeaItsAFourDoor
..::-Free your mind-::..
Default Drop some I-vtec knowledge
Wheews, it's been awhile since i've posted and I know most likely I should just search this question but I haven't found the answer yet and i don't feel like searching too long so i've decided to just ask you guys...
I remember the question i asked before about the concepts of vtec in which i was rerouted to the Why stuff works website...after reading that and talking to people at school i understand the basic concepts of it now...
but the popularity of RSX's at my school has brought up the subject of Ivtec... the only thing i really know about it, well i hope, is that the DOHC are controlled by computer rather than just the cam profile???? I'm just curious about it and my class doesn't teach Cams in depth like that...
Old Jan 23, 2004 | 01:21 PM
EKHatchRacer's Avatar
EKHatchRacer
every computer is run by computer
Old Jan 23, 2004 | 04:41 PM
pomansouth's Avatar
pomansouth
hey bud vtec is not controlled by cams, its oil pressure. anyhow IV-TEC is supposedly better for the around town driver due to better midrange then regular VTEC. do a google search and you can learn lots.
Old Jan 24, 2004 | 12:29 PM
YeaItsAFourDoor
My mistake i just though the oil pressure causes the cam to switch over...
Old Jan 24, 2004 | 04:41 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
i vtec has the vtec fuction, switching to a more aggressive cam profile when you are revving higher. it also adds adjustable intake cam timing. so it has different cam timing through out the rev range also.
Project EVA - The Track Package
Project EVA
Old Jan 24, 2004 | 05:02 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
I think the biggest benifit of Ivtec is the lovly torque curve it gives compared to oldskool vtec :chuckles:
Old Jan 24, 2004 | 05:43 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
i'm not sure what you meant by the DOHC being controlled by the computer??? its the computer that sends a signal to engage the Vtec solenoid and kick the pin to lock the rocker arms so the more aggressive cam lobes take over.
i believe that iVtec uses this method in addition to varying the timing far more by advancing or retarding the spark timing by +/- 20 degrees. with this new element, we can all see how the iVtec has lots of potential in tuning and why the Vtec cross over is smoother than regular Vtec.
anyone please add or correct... i'd like to know more advantages and disadvantages of iVtec... :goodjob:
Old Jan 24, 2004 | 06:04 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
pretty sure your correct Laubo, I saw a sheet on the iVTEC technology when the k20 was introduced online.. I cant remember the site, but im pretty sure you summed it up ^_^
Old Jan 24, 2004 | 06:59 PM
Kestrel's Avatar
Kestrel
Push to shock!
Yup I think you pretty much got it all
Old Jan 24, 2004 | 07:30 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
actually its the computer that controls the vtec system cause even if the oil pressure is there and the rpms are there the computer wont activate the solenoid unless you are going at least 25mph and are up to operating temp. but technically the oil pressure and cams work in unison to create vtec.
