Drop some I-vtec knowledge
Originally Posted by NeverBX
actually its the computer that controls the vtec system cause even if the oil pressure is there and the rpms are there the computer wont activate the solenoid unless you are going at least 25mph and are up to operating temp. but technically the oil pressure and cams work in unison to create vtec.
it's actually 15 mph.
well these are just safetey features, look at the dodge neon, i was driving a friends and it would not rev above like 3500 in neutral. anyhow there are plenty of factors that can come into play to limit the use of vtec but there is only one thing that starts the "chain reaction" of vtec. it all starts with the oil pressure.
So Ivtec is Vtec and VTC combined? Oil pressure of course is what helps start it but I-vtec is the advancement and retardation of the intake cam to adjust overlay and such for fuel economy and power along the band? Vtec is just the oil pressure causing a different set of cams to open and close the valves faster and long and VTC is the variable cam timing? Please correct me if im wrong...
Originally Posted by Kestrel
I think this probably has more to do with the higher displacements of the K20 than i-VTEC.
Originally Posted by pomansouth
i dont think so, accords dont benefit that much from minor mods. neither do crv's. one is a bigger displacement and the other is the same size as the k20.
They would probably benefit more than Civics with 1.6 or 1.5 L. Really the relevant parameter is the flow rate of air into the engine, which is a function of RPM and displacement. Since the K20 is a higher rev engine than the Accord or CR-V engine, so it would see more benefits. Subaru's, for instance, are 2.5 L and they see up to 15 HP from intake and exhaust alone, and most V8's see pretty large power gains from exhaust mods as well.
