GSR issues... :mad:
Originally posted by Spike
Sound's good to me. The timing and compression will be free, so I'll start there.
Do you think the fuel pump should come out, and the stock one go in?
Are you sure the engine is going into open loop mode? You may want to check/replace your temp sensor and sender. The sensor may fix your power problem, and your sender may fix yourgage problem. Have you checked TPS voltage?
Just some other ideas...
Well, I moved it out of the driveway this morning, and when I let up on the e-brake, it didn't budge. It seems like either the e-brake or the rear drums are stuck or frozen.
:wtf: :rant:
wned: :doh:
I'm gonna take it and have the brakes/e-brake checked. I mean, I drove it to a good size hill, and it doesn't roll down(move at all!) in neutral.
Any ideas? Stuck e-brake cable? Frozen drums?
:wtf: :rant:
wned: :doh: I'm gonna take it and have the brakes/e-brake checked. I mean, I drove it to a good size hill, and it doesn't roll down(move at all!) in neutral.
:wtf: :rant:
wned: :doh:
:wtf: :rant:
h:Maybe your car just has poltergeist, and its trying to screw you over :dunno:
