? about sway bars
Old Jul 29, 2002 | 02:01 PM
knight0118's Avatar
knight0118
Default ? about sway bars
If i add a front and rear suspension techniques sway bars to my civic...do i or can i still ad a front and rear lower tie bar?
Old Jul 29, 2002 | 02:23 PM
DSC's Avatar
DSC
Long way from home
Yes. Comptech makes a rear swaybar/tie bar combo.
Old Jul 29, 2002 | 02:36 PM
skubb's Avatar
skubb
not that TLC sh!t either
not all civics can have the sway bars added without adding other parts. lca's etc.
Old Jul 29, 2002 | 03:04 PM
knight0118's Avatar
knight0118
what about a 96 hatch...
Old Jul 29, 2002 | 03:16 PM
str8edgexx's Avatar
str8edgexx
I don't think so, but I'm not sure...go outside and look and see if you have the predrilled holes on your LCA
Old Jul 29, 2002 | 03:19 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I don't think your dx has the mounting points for a rear sway bar, but no biggie, just buy the sway bar designed for civic-no factory sway bar. It just bolts up around your lca's instead of int the little hole. And yes, they should both fit.
Old Jul 29, 2002 | 04:12 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
i believe all 96+ civic's had the holes for a rear sway to connect to the rear lca's.
If you are gonna get a sway bar get the ITR rear sway bar with the beaks kit.
easy to install and chaper than aftermarket, and it's probably just as big.
Project EVA - The Track Package
Project EVA
Old Jul 30, 2002 | 09:27 AM
CivicSilver's Avatar
CivicSilver
A little slow,...so ??
how hard is to install sway bar,
i about to buy ST sway bar for my 98 EX ? can you really tell the difference over stock bar
appreaciate your input
Old Jul 30, 2002 | 03:01 PM
str8edgexx's Avatar
str8edgexx
I just put my sway bar on this weekend. If your car has all the holes needed already there (and since you have a '98 EX, you have them there already b/c my '98 LX did), it should take you NO MORE than an hour to do. It's really a very basic mod that anyone with an ounce of mechanical ability can do.
btw...this is for a rear bar.
Old Jul 30, 2002 | 06:21 PM
CivicSilver
thanks for the info,
can u really tell the difference over stock, and what brand is yours.
