intercooler questoin
Old Jan 16, 2004 | 10:54 PM
blackcivicd16's Avatar
blackcivicd16
Default intercooler questoin
In a few months I'm going to get my car turbo charged, and I have a few questions. First about how many psi can the stock internals on a d16z6 engine take? I'm trying to get near the 200 hp mark what type of things internally should I look into? I've seen nitrous express advertisments for intercooler chillers( bar that sprays nitrous on the intercooler) do these actually produce as big of gains as they claim? would there be any benefits/problems with hooking up a purge system to one of those systems?
Old Jan 16, 2004 | 11:47 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Personally wouldnt waste money on the intercooler sprayer, it does give some power but ehhh. With proper tuning a d series should be able to run up to 15psi on stock internals. It would take some good tuning but it is possible.
Old Jan 17, 2004 | 12:19 AM
Outxider's Avatar
Outxider
X-Motoring
wow 15 psi is way pushin it. wit good tunin and fuel management u can run very well with 8-10 psi.
Old Jan 17, 2004 | 08:21 AM
blackcivicd16
15 seems a little high, most people i have discussed this with say around 8-10, so the gains from the intercooler sprayer aren't worth it?
Old Jan 17, 2004 | 08:56 AM
s1ngle's Avatar
s1ngle
clutch slipping boost
if you hit 10 psi, you should be darn near 200 hp
Old Jan 17, 2004 | 09:55 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
if youre paying for a nitrous kit, you might as well pay for one that sprays INTO the intake charge instead of just ON it. I don't know how much those sprayers cost, but its hard to imagine it being worth it.
If youre trying to get the most out of a stock setup, you might look into water injection. It lowers the intake temperature a bit, but more importantly, it slows the burning rate, giving you smother, more controlled combustion. That ads a major safety margin if youre running higher boost than you feel comfortable with.
I know this route isn't very popular with the honda folk, and I'm not quite sure why (let me know if you do), but my roomie has water injection on his car, runs nearly (occationally over) double the stock boost pressure (up to 23 psi, occational 2 bar spikes), has hack-job management and we don't have very good gas here. When we took off the head to do his head swap, everything was in perfect condition, no pitting or scarring that would indicate hotspots or dangerous a/f mixtures. I credit this partially to the stoutness of the saab motor, but also to the extra tuning cushion water injection gave us.
JMO
Old Jan 17, 2004 | 10:03 AM
oc_civic's Avatar
oc_civic
mcc racing
theres absolutely no reason to get a purge for that type of setup.. its rediculous...
Old Jan 17, 2004 | 12:17 PM
Jafro's Avatar
Jafro
I'm made of meat!
There's 3 things you can spray ON an intercooler. You can use water. You can use CO2 which is a lot more common. You CAN use Nirous oxide (kinduv stupid, though).
Usually when people have the intercooler sprayer on their nitrous kit, it's just hooked up to the purge. This is so that the wasted precious giggle juice that was paid for by the lb gets used for SOMETHING constructive. When you see someone's car doing this, it's more likely that they're using CO2 because it's much less expensive, twice as effective, and can be used in conjunction WITH N2O.
Marty, a guy I know with a heavily tuned Galant VR-4 (AWD 4-door that can pull the front wheels when it launches) reported nearly the same sort of gains with the CO2 sprayer. He achieved more than 100% efficiency with that combo, meaning the charge air... though more dense... was even colder than the ambient air temperature. BUT his intercooler core is over 30" long, 12" tall and 3.75" thick. It was already very efficient. I've heard FWD reports that it's the difference between traction in 3rd gear, and no-traction torque-steering all the way through 3rd gear. I never trust anyone else's butt dyno, but it wouldn't surprise me one bit if they have a large enough intercooler.
What everyone needs to know about water injection is that you have to be running AT LEAST 17 PSI. The water won't atomize well enough at lower pressures for this system to work. It's pretty widely used in the DSM circles. It only costs about $300 to install, and it's worth nearly a hundred horsepower on a properly tuned car. Amazing. Not only does it cool everything in the combustion chamber, but it also cleans everything out of the combustion chamber. Carbon won't stick to an engine that's running water injection. Most Hondas can't handle 17PSI on stock internals for very long (if at all). I don't think any OEM Honda head bolts could hold it either. You won't find water injection to be even a possibility with your Honda unless you LOWER its compression, enabling you to run higher boost.
There's a local guy whose name I forgot, but he has a blue Scubaru WRX wagon running low 12's. He's utilizing a pressure-activated home-made water sprayer setup on his IC core, and says the core has never heat soaked. Most of what made his car fast were hacks, but he pulled it off nicely. Overall it was a sweet setup. A lot faster than mine.
Just goes to show you that any one of those setups work. The reason any of these systems exist is to prevent heat soak. So basically, unless you're able to heat soak your FMIC, you don't need them, but in some ways you can still benefit from them.
If you get a intercooler sprayer that uses a gas, go for CO2 instead. Using nitrous oxide for that purpose is stupid. Either way, if the car is driven on the street, it will just be a fashion accessory. I'd reserve plans for that setup unless you spend every weekend at the track.
Old Jan 17, 2004 | 12:25 PM
white_n_slow
it's my D in a B
Thanks, that kinda answered my question (why doesn't everybody use h20 injection) My roomie's saab is usually running between 18-23 psi, works wonders on his car.
If thats the case, though (only good for high boost), i wonder why the JRSC uses h2o inj for only 8 or so psi? :thinking:
Thanks for the info jafro
Old Jan 17, 2004 | 06:14 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
another thing you could do is a water/alcohol mix....which would be slightly more effective than plan old water
the jrsc uses h2o injection because there is no other way to cool the charge like an ic
