intercooler questoin
8-10PSI right around 175-200 hp setups are very common with the vtec D16 motors. I think the consensus will be that tuning is the most critical factor. Also the OEM MAP sensor is only good to 10.6 PSI anyways, so that is a limiting factor.
-PHiZ
-PHiZ
Originally posted by PDiggityDogg
another thing you could do is a water/alcohol mix....which would be slightly more effective than plan old water
the jrsc uses h2o injection because there is no other way to cool the charge like an ic
