engine swap questions
Old Jan 9, 2004 | 11:08 AM
Kai's Avatar
Kai
Rotorphile.
Or dark grey, if you don't use the new color scheme. Which sucks, BTW.
Old Jan 9, 2004 | 11:21 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I didn't know I could pick
Old Jan 9, 2004 | 11:23 AM
Kai's Avatar
Kai
Rotorphile.
User CP: Edit Options: Style Set: Black/Grey :thumbup:
Old Jan 9, 2004 | 11:35 AM
white_n_slow
it's my D in a B
oooo....
Old Jan 9, 2004 | 10:58 PM
supermac88's Avatar
supermac88
not OG but Old School
Originally posted by pomansouth
there is a really good saying that a member has at the bottom of his or hers sig that says, the only work that you need to put into a d series, is to swap it out. im not taking credit for this seeing as though someone else said it before me.
I disagree, d series engines can be quick. For quite a bit less than a b16 swap I swapped a d16z6 and have a home made turbo kit waiting to go on. More than likely I will be quicker than the b16 swap on a d. So you do the math is it pointless?, should I not have done it?
Old Jan 9, 2004 | 11:34 PM
Civic2Scooby's Avatar
Civic2Scooby
ok but what if I slap that same turbo on my b16? well mine will make more power....the question wasnt about if a d16 could make power, it was about the d15...which is a peice of shit...if he is gonna swap it, I would do a b series swap and then turbo which will yeild you way more than any d series turbo combo
Old Jan 10, 2004 | 12:33 AM
supermac88's Avatar
supermac88
You are correct, but figure in b swap plus turbo costs, and you have spent a shit load more money than me with a good d swap and a turbo. Will you be faster, yes. Will you be more broke or in debt, yes. Just giving this guy viable options is all.
Old Jan 11, 2004 | 09:14 AM
cooliojones's Avatar
cooliojones
Ok so which is more work though? The swap or the turbo mod?
Old Jan 11, 2004 | 09:46 AM
Kai's Avatar
Kai
Rotorphile.
A swap is more work, but neither are very difficult.
Old Jan 11, 2004 | 10:12 AM
s1ngle's Avatar
s1ngle
clutch slipping boost
not to mention the fact that d series engines only run a couple hundred, and B series can run a couple thousand thats a HUGE difference if you ask me.
