Bad idea to use impact wrench on lug nuts?
Old Jan 3, 2004 | 08:01 PM
SRT_Andy's Avatar
SRT_Andy
Originally posted by Jafro
That only happens if you're a pussy. :chuckles:
Well, I might have to wimp out if I lose the upper half of my body when i slide into the car/truck in front of me...:barf:
Old Jan 3, 2004 | 09:32 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Air gun is fine for pulling the lugs off, I do it all the time, but you don't want to put them back on the same way. They'll be much harder to remove on the side of the road with just a little lug wrench, could strip the stud or lug nut, and you could help warp the hub and rotor. Just hand tighten them back on and use a torque wrench to get them to 80 in a crisscross patern.
Old Jan 3, 2004 | 11:45 PM
supermac88's Avatar
supermac88
not OG but Old School
or you could actually break the stud, I did this and my tire went bouncing down the road off of my lifted s-10 when I was 16. I somehow managed to break all 5 lugs.
Old Jan 4, 2004 | 06:04 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Actually the Kosei K1s they tell you NOT to use an impact wrench or you will crack your wheel. I've seen one RIP Kosei K1.
Autocross Help Page
Old Jan 5, 2004 | 02:33 AM
Black '98 Civic's Avatar
Black '98 Civic
I've used an impact wrench to put my new wheels on before. As long as the setting is down all the way it was always fine. I was able to take the lugs off easily with a tire iron too.
Old Jan 5, 2004 | 06:43 AM
Redcivic's Avatar
Redcivic
One of the original OG's
I use an impact to take off and put on all the time. Just when you put them on set your gun to the lowest setting and then use a torque wrench (I just got a new Husky one too for christmas) to get them to 80 ft/lb. I have been using torque wrenches on every set of alloy wheels I have owned and I have a bad ass 700ft/lb 1/2" drive impact. Just have to be conscious of what you are doing. Trust me, after completing a swap the last thing I wanna do is hand tighten eight lugs.
Old Jan 5, 2004 | 10:28 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Originally posted by CivicSiRacer
But my cordless drill maybe tightens about 50ft/lbs then the rest I do with a torque wrench from Husky.
Yup 80ft/lbs total, in a staggered or cross pattern. Torquing the different lugs to different specs can warp rotors/wheels, and make it feel like your tires are imbalanced.
civicsiracer, the way i've always understood things, is that you want to try and torque everything once, all the way to redline, whatever, if you do a dual stage torqueing, the second time around you're measuring a bit of friction instead of true torque. yeah/nay?
-PHiZ
Old Jan 5, 2004 | 11:32 AM
CivicSiRacer
-PHiZ
This is the way I do things:
  • Make sure each lug has some anti-seize in it. I put some on every year. Makes engagement of the threads smoother.
  • Put the lugs on by hand maybe 1-2 turns.
  • break out the cordless drill get everything on.
  • torque everything down with torque wrench to 80ft/lbs
  • roll car back and forth about 3-5 times.
  • retorque the lugs once more.
Autocross Help Page
Old Jan 5, 2004 | 12:06 PM
PHiZ's Avatar
PHiZ
BOOST GOD
This is the way I do things:[/list]
Well, can't argue with results. :thumbup:
-PHiZ
