Turbo?
Starion IC's suck ass. 95-99 DSM side-mounts work better, and don't require extensive modification to your car to accommodate its plunderous bulk like the StarQuest IC does. You can find them for $25-$50. Hell, I've got one in my shed that I don't need anymore.
There's an adapter plate that you can get that allows you to use a CX exhaust manifold with a TD05H DSM turbo housing. Strangely enough, I have one of those [manifolds] laying around, too.
Do you know what size the can of worms is that you're opening?
You can use the:
turbo
intercooler
blow off valve
But, like Kai said, that's about it.
Also, check out www.homemadeturbo.com for some info on setups like the one you're thinking of.
Also, first research turbos a lot. And listen to Jafro
:thumbup:
turbo
intercooler
blow off valve
I'd get the whole motor if I were you. D15 internals are crap compared to D16 internals. Doing the mini-me swap is 4x as difficult as swapping a motor. It will also cost you less, provided that you have hook-ups like an uncle with a junkyard. The end result is better, too.
You can't re-use a head gasket, and the timing headaches.... easier to just do this stuff out of the car. If you have a complete donor car, there's no reason to mini-me.
But yes, I agree, get the whole D16 motor. It will be easier to put in, and you will get more HP and a stronger overall motor. Then boost it
