adding power steering
Old Dec 23, 2003 | 06:34 AM
1995integraLS's Avatar
1995integraLS
Default adding power steering
is this possible on a 93 cx hatch that came with none?
keep in mind im dropping in a 2000 gsr motor. how complicated and how much would this procedure cost. thanks
andy
Old Dec 23, 2003 | 08:40 AM
Outxider's Avatar
Outxider
X-Motoring
u would have to swap out ur manual steerin rack to a power steering rack, then run all the plumbin and reservior. imo its not worth it and very time consuming.
Old Dec 23, 2003 | 06:31 PM
supermac88's Avatar
supermac88
not OG but Old School
Just wondering why would you swap to get better power, and then take away some power by using power steering?
Old Dec 23, 2003 | 07:58 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default Re: adding power steering
Swapping the racks is easy, but you do need to use the GS-R rear engine subframe. Basically the CX non-PS rack is a lot skinnier than a PS rack, so the subframe is designed to hold that tight. I doubt a GS-R rack would fit (if you can't visualize it, I can post pics, but I have to get onto another computer). I swapped a GS-R rack onto my '92 CX but without the power assist stuff. A little more effort than the CX rack but might tighter turning radius and a lot less turns lock to lock.
I'm assuming you swap over all the PS stuff and make it work, but it's probably going to be a hassle finding all the hardlines intact. My rack and swap (got each at seperate times and from seperate cars) had part of the hardlines still attached but cut somewhere, I'm guessing it's just a lot easier to remove that way and nobody usually uses the lines.
