Hood release...
Old Dec 17, 2003 | 05:35 PM
cvcsleeper's Avatar
cvcsleeper
Boyashaka!
Default Hood release...
I have an EK and my hood release latch doesn't work anymore. Well technically it works, it does pull back, but it doesn't release the hood. I have to screw around with the hood for a bit (push it down and lift it) before it opens. Is this common for Civics? Anything I can do to fix it?
Old Dec 17, 2003 | 05:55 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
i would check the latch, make sure it's releasing like it should.
Old Dec 17, 2003 | 06:14 PM
habitatsk8r392's Avatar
habitatsk8r392
Certified Ricer
lubricate it, thats the biggest problem usually
Old Dec 17, 2003 | 07:39 PM
cvcsleeper's Avatar
cvcsleeper
Boyashaka!
Thank you much!
Old Dec 17, 2003 | 07:52 PM
supermac88's Avatar
supermac88
not OG but Old School
my theory is if it don't move use some good ole silicone spray lubricant i personally like BG products but anything will work
Old Dec 17, 2003 | 08:24 PM
habitatsk8r392
Certified Ricer
no way, i actually had a RIGHT answer for once??
man that is just FLY :fawk: :fawk:
Old Dec 17, 2003 | 10:36 PM
Hondaman's Avatar
Hondaman
Black Pearl
White Lithium grease in a spray can works very well too. It tends to last a lot longer than silicon does too.
Old Dec 18, 2003 | 04:13 AM
J'silverHb's Avatar
J'silverHb
mine did that that, I sprayed some break wash in there and it cleaned right up. i also pulled mine to far once if that happened u might need more than a good lube
