interior lighting?
Old Dec 16, 2003 | 07:29 AM
Redcivic's Avatar
Redcivic
One of the original OG's
Default interior lighting?
Okay, so I have been driving my bosses S500 for a couple of days and aside from everything being built rock solid and the straight pimp appeal, the main thing I like is the vehicle lighting. I mean when you open the door everything lights up like your in an office or something. The lighting sucks in my civic and is not great in my GXE so I would like to pump up th elighting. Any suggestions? I'm thinking of getting a mirror with the map lights but is there some type of aftermarket dome light I could replace the stock one with?
Old Dec 16, 2003 | 10:30 AM
Nelson's Avatar
Nelson
Administrator
You can install a maplight like 18Sec did. Pretty neat. Unless you want to go all out and install the rear pillar lights and all.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Dec 17, 2003 | 03:11 AM
pliepl's Avatar
pliepl
how about something like that. parts (ccfl tubes/inverters) cost about 12 bucks for both sides. the only hard part is to tap into the door trigger wire if you wanted them to go on/off with the door like i have mine.
Old Dec 17, 2003 | 06:48 AM
Redcivic's Avatar
Redcivic
What about the dome light too? Where did you get those tubes? I already have an inverter. What map lights did 18sec get?
Old Dec 17, 2003 | 08:12 AM
pliepl's Avatar
pliepl
i didn't do the dome light on my car, just the floor lights.
http://store.yahoo.com/glowingstuff/du12winco.html
the white ccfl's that i used, i got them from there.
this place now carries the white ccfl's and their price is lower, http://www.case-mod.com/store/produc...roducts_id=620
Old Dec 17, 2003 | 08:35 AM
Jafro's Avatar
Jafro
I'm made of meat!
The rear-view mirror of a Mitsubishi Eclipse GS-T or GSX (and some GS models) with a factory sunroof has a bad-ass set of map lights built into it with individual swithches for each side that let you turn it on without the door open. The switches don't override the door-open trigger, either. Bright, and you don't have the lights shining in your eyes or mirror when it's on. They shine on the dash, and light it up like a stage.
If you get one, be sure to also get the wiring harness that extends to it. It has a clip-in connector on it that you'll want to use. Some Galants also have it, but I'm not sure specifically which ones.
Old Dec 17, 2003 | 11:05 AM
Nelson's Avatar
Nelson
Administrator
You know I did make a BIG mistake in speaking about lighting and NOT mention PLIEPL.
:bowdown:
I did that same lighting to my car with blue :rick: but then I took it off.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
