clutch grind
Old Dec 15, 2003 | 08:29 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Default clutch grind
Hey i have an excedy race clutch in my Z6 it is about 9 months old. the tranny has 120k on it. When i shift in to 2nd and 3rd it doesn't fully grind but chrips. Is that a Presure plate/clutch problem or is it a Slave cylinder prob. the SC has 168k on it. Also where can i find a stainless steel clutch line?
Old Dec 15, 2003 | 09:09 PM
Kai's Avatar
Kai
Rotorphile.
Could be either. If double-clutching makes the problem disappear, I would look closely at the slave. Hell, it's the cheapest to replace.
Old Dec 16, 2003 | 05:21 AM
supermac88's Avatar
supermac88
not OG but Old School
Default Re: clutch grind
almost sounds like a trowout bearing? I could be wrong but they kinda squeek when they are going out.
Old Dec 16, 2003 | 08:10 AM
HatchVX's Avatar
HatchVX
its not a squeek, its a grind but not a long one. It engages but not fully, thats all.
Old Dec 17, 2003 | 12:12 PM
mitsurugi's Avatar
mitsurugi
Super Member
Mine does a similar thing on the second to third shifts. I also have a z6 motor and tranny. From my research I think its the infamous Honda synchro problem. Does it ever not shift fully into third gear? Also, is it on every shift or just at higher rpm's?
Old Dec 17, 2003 | 06:18 PM
HatchVX's Avatar
HatchVX
its only 2nd and third its about mid range one the RPMs
Old Dec 17, 2003 | 07:44 PM
supermac88's Avatar
supermac88
mine wont go into reverse all the time and I grind third a lot now, I think my clutch might be going out what do yall think? Oh yeah and if I try to launch at around 5k it will grab, but not really spin the tires very much at all anymore.
Old Dec 17, 2003 | 08:49 PM
habitatsk8r392's Avatar
habitatsk8r392
Certified Ricer
sounds pretty normal to me, try shifting into one of the other gears before trying to put it in reverse...
Old Dec 18, 2003 | 06:50 AM
Wharbone's Avatar
Wharbone
Yeah, mine won't go into reverse sometimes. I just put it in 4th first, then shift to reverse. Seems to work for me.
Old Dec 18, 2003 | 10:12 AM
supermac88's Avatar
supermac88
yeah that works for me as well but it is just really annoying
