ball joint boot....
Old Dec 14, 2003 | 01:26 PM
honda1998civic's Avatar
honda1998civic
Default ball joint boot....
i replaced my cv shafts... the ball joint boot got stuck.. it needs more grease correct? how do put in more grease if it has no fittings? do i inject it in there? will it squirt out as im driving? let me know what i should do. thanks
File Type: jpg
Old Dec 14, 2003 | 01:37 PM
luderone's Avatar
luderone
I don't think you can fill it with grease, because if a ball joint is bad you have to replace the whole controll arm, casue the ball jont is one peice with the arm.
Old Dec 14, 2003 | 01:39 PM
honda1998civic
oh damn... i meant the boot where the control arm is held by the castle nut...
Old Dec 14, 2003 | 01:53 PM
luderone's Avatar
luderone
yea thats the one, becuse if you look on top of the ball joint, you can see that it is welded.
Old Dec 14, 2003 | 03:47 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
you're wrong luberone.
The upper A arm ball joints are not replacable because they are part of the A arm.
The lower ball joint that goes into the LCA is replaceable. You have to remove the hub from the car to replace it, but it can be done (I did mine not too long ago).
Now, as for the grease:
If you look at the top of the boot, there's a metal spring keeper that goes around the whole thing. Remove that and you can slide the boot off to put more grease in there.
hih
Old Dec 14, 2003 | 04:37 PM
honda1998civic
hmmm.... westcoast ur da man!!!!!!! Well.... i went and bought a needle and injected it that way.. it worked fine.... it looked as if it had been previously done that way because grease squirted out of another little hole... Looked like a long blackhead... hehe.
Old Dec 14, 2003 | 08:06 PM
westcoaststyle
Sorry man, but I wouldn't have done it that way. You will now need to replace the boots far sooner than you would have had you taken them off. The grease will end up working its way out of the hole and will eventually make the hole bigger.
Live and learn.
Old Dec 15, 2003 | 07:40 AM
honda1998civic
damn... i guess ill live and learn.. cant undo it.. whoops...
Old Dec 15, 2003 | 11:16 AM
h22avid's Avatar
h22avid
Sleeper...Creeper...
hih
Hey, were you able to get the old ball joints out and the new ones in without the bench compression tool? I know they are compressed in and what I know of it is that you need the tools to get it out and replace it. Just wondering because mine need replacing.
Old Dec 15, 2003 | 11:33 AM
westcoaststyle
I used a large socket and a nice hammer :rick:
