ECU Install Please Help
Old Dec 5, 2003 | 12:12 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
and that is exactly why i asked for the reason of swapping it out!!! :yay: go me!!!
Old Dec 5, 2003 | 01:15 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
It will not work with your engine and could potentially destory it (also probably won't plug in anyway). If it did, it would imediately throw a check engine light casue your engine doesn't have a knock sensor and the ECU will want to see one. Also the redline of a JDM B16A is 8000 rpm, your is 7000. Your stock D-series cams peak out at around 6700 rpm so there's no power to be gained by going past. If you were to take it all the way to the B16A fuel cutoff of 8300, most likey your stock valve springs couldn't react fast enough and you'd float a valve (it wouldn't close when the cam lobe went away) and a piston will fly up and smash into it (your valves open and close over 66 times a second at 8000 rpm) and your motors destroyed.
Stick with your stock ECU.
Old Dec 5, 2003 | 02:16 PM
SUPER LAUBO
KiMBO's Hubby
geesh, when you make it that graphic i don't even wanna rev my motor past 5k :eek3:
Old Dec 5, 2003 | 02:24 PM
SRT_Andy's Avatar
SRT_Andy
I didn't know that this was your thread. Did you change user names or something? Sounds that way to me.
Old Dec 5, 2003 | 02:42 PM
chefbt's Avatar
chefbt
The ECU Code is:
37820-p2t-a12
But from what I am hearing, I should not bother.
Let me know what you think.
Any other suggestions for a reasonable priced mod to get some more oomph out of this thing? Especially lower-end?
Thanks
Old Dec 5, 2003 | 02:57 PM
SRT_Andy's Avatar
SRT_Andy
Buy a car that's already fast or get a supercharger. If you want to go REALLY fast, get a turbo.
