JDM or not????
Old Dec 4, 2003 | 03:37 PM
CivicSi99's Avatar
CivicSi99
Default JDM or not????
I bought a 99 SI and the check engine light came on. When I took it to Honda they said I needed a oil pump because my motor was a JDM. The engine has b16a with no number after the a so they said its not american made. Had anyone had the problem with the oil pump on a JDM??
Old Dec 4, 2003 | 07:53 PM
dantastic's Avatar
dantastic
cx power!
jdm motors usually lack an oil pressure switch (located by the distributor, by the vtec solenoid.) do u live in canada? if u dont, u got jacked. someone replaced ur stock motor with a jdm one. weird.
Old Dec 4, 2003 | 08:13 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
I always thought that was how you tell the JDM motors from the USDM ones.
My friend got a JDM GSR engine and it just says B18C
Old Dec 5, 2003 | 09:27 AM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
If it was usdm it would say b16a2. The motor you have is probably an early 90's jdm crx or integra motor. I think you can tell by the number below the b16a.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Dec 5, 2003 | 10:25 AM
Civic2Scooby's Avatar
Civic2Scooby
you can tell what year it is from by the date stamps on the head.
Old Dec 5, 2003 | 11:37 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
yr of the motor usually is 1yr before the yr of the car
so a 96 comes out of a 97...
(9 times outta 10)
Old Dec 5, 2003 | 12:16 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
its not a matter of JDM or USDM that makes the difference. i suppose they used the same factory pump manufacture...
its probably from wear and tear due to aging since it could be an older motor
Old Dec 5, 2003 | 12:32 PM
loodboi's Avatar
loodboi
هونده بريلود
Isnt JDM motors better than USDMs? They are more powerful? A EDM B16a2 motor has 160hp, and the JDM has 170hp. Difference
Old Dec 5, 2003 | 12:35 PM
qtiger's Avatar
qtiger
Yeah, but this motor probably has triple the miles of the original.
