JDM Civic pics needed 56k death
Old Nov 30, 2003 | 11:42 AM
  #71
Civic2Scooby's Avatar
Civic2Scooby
Originally posted by Grifter
the original topic
awww I got wned:
Old Nov 30, 2003 | 01:12 PM
  #72
loodboi's Avatar
loodboi
هونده بريلود
nice jdm coupes
Old Nov 30, 2003 | 01:42 PM
  #73
92b16vx's Avatar
92b16vx
There were still 5th gen coupes in Japan, it doesn't matter that they were made in America (they were maing RHD's right under our noses?!), they were sold in Japan, by Honda, that makes them Japanese Domestic Market.
Old Nov 30, 2003 | 02:34 PM
  #74
EJcivic02's Avatar
EJcivic02
I talk Before I think
:werd: so both of us were right
in conclusion:
yes, there are JDM coupes that are sold and driven in Japan.
no, there was no production of 5th gen coupes in Japan
im getting this from what ive read, so is this correct?
Old Nov 30, 2003 | 02:54 PM
  #75
Civic2Scooby
yea....and the rhd ones were made in the UK not the US....so I guess we were both right on this one...they dont make them but I guess they drive them and sell them...so whatever...we all learned some new knowledge :thumbup:
Old Dec 3, 2003 | 10:29 AM
  #76
92b16vx's Avatar
92b16vx
If I may direct your attention to Hondas Japans website, http://www.honda.co.jp/HOT/ModelData...302/cp_sy.html
You will find the spec page for the 93-95 EJ1 coupe as it was availible in Japan. Now if I can direct your attention to the first line, and the last paragraph, you will see that it was indeed produced and exported from the United States, not the United Kingdom.
Item Specifications
Car name type HONDA of American E-EJ1
Transmission Lockup mechanism attaching 7 position 4th gear automatic
Total length (m) 4.390
Full-width (m) 1.695
Total height (m) 1.345
Wheel base (m) 2.620
Tread (m) Before 1.475
After 1.465
Roadspace (m) 0.150
Vehicle weight (kg) 1.070
Riding in a car fixed capacity (name) 5
Size inside passenger compartment (m) Length 1.845
Width 1.350
Height 1.095
Engine type D16A
Engine type Water cooling serial 4 cylinder horizontal ranging (unleaded gasoline use)
Combustion chamber type ƒyƒ“ƒgƒ‹[ƒt shape
Valve gear SOHC belt driving inhalation 2 exhaust 2
Total cubic displacement (cm3) 1,590
Inside diameter ~ distance (mm) 75.0~90.0
Compression ratio 9.2
Fuel feeder type Electronic fuel injection system (HONDA PGM-FI)
Fuel pump type Electromotive system
Fuel tank capacity (L) 45
Lube capacity (L) 4.0
Lubricating system Force system
Ignition device type Full transistor type battery ignition
The highest output (PS/rpm) * 130/6,600
Largest torque (kgm/rpm) * 14.8/5,200
10 15 mode travelling fuel consumption rate (km/L) 14.0 (Ministry of Transport examination value)
Minimum turning radius (m) 5
Braking braking distance (m) 15.5 (At the time of initial velocity 50km/h)
Clutch type 3 element 1 step 2 phase shapes (the lockup clutch you attach)
Transmission type Regular gearing system
Transmission operation system Floor change system
Change gear ratio 1st gear 2.600
2nd gear 1.393
3rd gear 0.926
4th gear 0.673
Retreat 1.954
Reduction gear ratio 4.333
Steering device type Rack & pinion system (power-steering specification)
Tire (before & after) 185/60R14 82H
Type type of main brake Before Hydraulic type ventilated disk
After Hydraulic type leading trailing
Braking booster type Vacuum boost system
Actuating unit and braking wheel The right 1 wheel of 2 systematic ceremonies ago - the left 1 wheel before the rear left 1 wheel - rear right 1 wheel
Suspension system ƒ_ƒuƒ‹ƒEƒCƒbƒV�cƒ{[ƒ“ system (before/after)
Stabilizer type Torsion bar system (before/after)
* "Net value": "The net" as a state where the engine single unit is loaded onto the vehicle it is something which was measured under the almost same conditions. When it measured with the same engine, the value which approximately 15% is lower "" Gross "(our manufacture meeting) with it has stopped inspecting than the net".
* Indication of the fuel consumption rate in the time of mode travelling "10 15 modes" stop inspecting because high-speed travelling and the like inside the city is added, when it measured by the same vehicle, "10 modes" an evenly small size, normally approximately 10% higher value (our manufacture meeting) with by the car.
* As for fuel consumption rate, it is value in the origin of the test condition which is decided. Because this condition (weather, circumstance such as road, vehicle, driving and service) differs at the actually travelling time, fuel consumption rate differs in consequence of that.
* PGM-FI is registered trade mark of the Honda Motor Co., Ltd. corporation. VTEC is trade mark of the Honda Motor Co., Ltd. corporation.
* The model designation application numerical value due to road haulage vehicle method
* Production enterprise: HONDA of America Mfg. and Inc. (country of manufacturer: The United States of America) * import sale origin: Honda Motor Co., Ltd. corporation
These contents are produced on the basis of 1993 February present catalog.
Old Dec 3, 2003 | 10:56 AM
  #77
Grifter's Avatar
Grifter
is that you john?
btw the guy is asking for info on ek coupes :fawk:
Old Dec 3, 2003 | 11:22 AM
  #78
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
damn, tooo much scrolling.. shiet, now my finger hurts :happysad:
nice cars!!!!
Old Dec 3, 2003 | 11:33 AM
  #79
oc_civic's Avatar
oc_civic
mcc racing
why does it matter where it was made? to me "jdm" is something that was offered to those people in that market.. i think it is inconsequential where is was made... to say something is not the japanese version of a certain car because it was made in mexico (just an example) is silly... if it was sold at a dealer in that region then it is of that regions market... regardless of anything else..
i can understand the thought process that if it doesn't have something that makes it "cool" or "differant" then it is not "jdm" but that is just not the case
Old Dec 3, 2003 | 12:50 PM
  #80
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
ctr coupe?
