rear tire problem
Old Nov 22, 2003 | 04:59 PM
Wharbone's Avatar
Wharbone
Originally posted by oc_civic
where do you get hubcentric rings
I'd either get them though cashiseg8, or off ebay. Ebay always seems to have the metal ones. Search under Rota.
Old Nov 22, 2003 | 10:35 PM
twistdCivic's Avatar
twistdCivic
any tire shop should have them
Old Nov 22, 2003 | 11:00 PM
smudge's Avatar
smudge
You could have a bad tire. Have you hit any large potholes lately?
Old Nov 23, 2003 | 08:37 AM
J'silverHb's Avatar
J'silverHb
i did hit a pretty nice one not too long ago. but wouldent it damagae the rim more than the tire. thanks again for your help everyone
Old Nov 23, 2003 | 10:03 AM
igo4bmx's Avatar
igo4bmx
CockBlockerator
potholes can damage tires too man...
check your sidewalls for bubbles and such to see if it got damaged
Old Nov 23, 2003 | 10:07 AM
YeaItsAFourDoor's Avatar
YeaItsAFourDoor
..::-Free your mind-::..
Impact bubbles suck....
Old Nov 23, 2003 | 05:57 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
check the rim to see if it is warped. my friend didnt know his was warped until he got some new tires....the balancing machine was not able to balance the rims.
Old Nov 23, 2003 | 08:40 PM
J'silverHb's Avatar
J'silverHb
well i looked myself and i didnt notice that it was warped it could be a so minor i cant see and if so how could i get it checked out...
Old Nov 23, 2003 | 10:00 PM
Technodigifreak's Avatar
Technodigifreak
Hot-Modder
I've got a few q's for you--or just a good picture of the tread from teh tires will work
what speed does begin and end at? and what speeds does it produce noise?
do your wheels require hubcentric rings?
Have you had your suspension checked recently?
How often do you rotate your tires?
when was the last time you hit a pothole at a decent speed? and was that tire up front when you hit the pothole?
when you had your wheels balanced did they mention anything about cupping or seperation or flatspots?
when you run your hand over the tread, do you feel any highpoints or ridges, and does it occur in any sort of a pattern?
Old Nov 24, 2003 | 04:35 AM
J'silverHb's Avatar
J'silverHb
1. about 25 but i can always feel it
2. not that i know of at least not the back ones
3. i have koni yellows and skunk 2 and ithey feel and look and feel fine
4.never had a problem or thought i needed to rotate ( no dramatic wear.
5. not to long ago and it was the front i think and the front is fine
6. the mentioned a couple flat spots from being of balance but i think it to minor to be the problem but maybe it is.
7. as i said the funny wear is to minor to cause this or is it just enough i dont know.
should i just break down and get new tires to see if this is it and i also have time tues i might rotate them just to see what happens
