'92 rotor and caliper dimensions/specs
Do you guys know of any links where I can find dimensions and specifications for the rotor and caliper of a 92 civic dx?? its for a mech eng autocad modeling project. Help would be greatly appreciated
the only thing i've ever seen about brakes.
Front
10.3 in vented disc
Rear
9.4 in disc w/ABS (EX Sedan, Si Hatchback, EXa Coupe, Available on LX)
7.9 in drums (DX, LX)
7.1 in drums (VX, CX)
Assist type
vacuum
Front
10.3 in vented disc
Rear
Assist type
vacuum
To my knowledge. the EX front brakes are larger than the standard LX/DX models. I think it's 8.5", if not, then I think 10.31" is the correct number. I will double check my Helms manual when I get home, on that. But I am positive the thickness is 21MM (or .82"). The rear is 9.4" with .35" thickness
Stock calipers have a weak 1 piston caliper :shocked: and the piston diameter for the front should be 2.12", the rear is 1.19". Talk about weak stoppping power.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
