~Clutch Problems~
Old Nov 9, 2003 | 03:48 PM
guster900's Avatar
guster900
Default ~Clutch Problems~
So when I got my car a few months ago, I noticed a slight noise ocasionaly when starting out in first gear. A whining, grinding type of a squeal. But it shifted fine and drove great. Yesterday I drove my car quite allot, and everything was normal. My clutch was never perfect, but still pretty good. Didn't have much freepaly. Today I go to drive it, and it's like, total freeplay. the clutch does nothing when I push it in until the very end, maybe the last 2 inches. It still shifts and drives, but what happened? What should I look to fix first? Could I just adjust the clutch cable somehow? Why would it all of the sudden develope total freeplay in the pedal? Any advice would be appreciated. Thanks, Dan
Old Nov 9, 2003 | 05:12 PM
Vividkid82's Avatar
Vividkid82
worn out pressure plate, but try adjusting the clutch cable.
Old Nov 9, 2003 | 05:25 PM
supermac88's Avatar
supermac88
not OG but Old School
what year is it, plus if u are posting here wouldn't it be hydraulic, check your fluid maybe and bleed the system
Old Nov 9, 2003 | 05:35 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
you may some internals crapping out, perhaps a synchro. Don't worry though, d16 trannys are a dime a dozen i'm on my 5th
Old Nov 9, 2003 | 08:48 PM
guster900's Avatar
guster900
Default 94 civic
It's a 94 civic EX, 133,000 miles. The fluid was low so I filled it, but no change. So could I just buy a $150-$200 clutch kit? Would that most likely fix it? How hard is that repair....
Old Nov 9, 2003 | 11:11 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
It could be the pressure plate, or you might just need to bleed the line. did you see any wety spots under the hood, of on the ground?>
Old Nov 9, 2003 | 11:47 PM
5GVTEC's Avatar
5GVTEC
Maybe the throw out bearing going bad? Just get a new clutch and see what happens.
Old Nov 9, 2003 | 11:54 PM
Smurf's Avatar
Smurf
Dancing Banana Driver
Prehaps if you stoped buying crap used parts, you wouldnt need 5.
Old Nov 10, 2003 | 12:46 AM
93HybridCX's Avatar
93HybridCX
Beast from the East
:werd: thats what I say it is by what you described was happening
Old Nov 10, 2003 | 05:41 AM
95civicEX_h22's Avatar
95civicEX_h22
Slo N Low
Try bleeding the clutch before you buy anything. My reservoir went dry without any signs of leakage.
I bought an ACT street clutch, then found out that i only needed to bleed the system.
Not that i'm bitching, but i could have saved 250 bucks for at least another 30k, but i love the new clutch
