Taking off crank pulley
Old Nov 2, 2003 | 07:42 PM
ManTiS's Avatar
ManTiS
NinJA
Default Taking off crank pulley
Hey, I need to hear how you guys are taking crank pulley bolts out. I did mine fine, but I had trouble with my buddy's '92 SI.
Remember, hand tools only.
Old Nov 2, 2003 | 07:57 PM
Daniel's Avatar
Daniel
I removed the flywheel cover on the bottom of the engine, jammed a big screwdriver in there, pinned it between the teeth of the flywheel and....the header I believe, then took socket, wrench and big pipe, and kicked the pipe on the wrench till it loosened. Took one good kick!
Old Nov 2, 2003 | 09:26 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Exactly. :thumbup: That's what I've been doing forever with em.
Old Nov 2, 2003 | 10:06 PM
qtiger's Avatar
qtiger
Moroso crank pulley tool.
Old Nov 2, 2003 | 11:08 PM
dantastic's Avatar
dantastic
cx power!
put the car in gear, and have somone hold the brakes. i was able to take the pulley bolt off with a 24" lug wrench
Old Nov 3, 2003 | 06:44 AM
Redcivic's Avatar
Redcivic
One of the original OG's
I have the Moroso tool and a 500 ft/lb impact but before that I used to use a chain wrench and a big ass breaker bar. The chain wrench works but is a pain in the ass. The before mentioned ways could potential damage stuff. With my impact I barely have to hit it and it comes off. But my crank pulley has been off like twenty times so on a car where it has never been off, it will be much harder. Other companies make tools like the moroso wrench but they are expensive. Just rent a chain wrench from autozone.
Old Nov 3, 2003 | 11:50 AM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
:thumbup: :bigok: :boink: :irock: :bowdown:
That thing makes life SO much easier.
Old Nov 4, 2003 | 12:20 PM
ManTiS's Avatar
ManTiS
NinJA
Okay, I know how to hold the crank pulley. I use the chain wrench method and it works fine on my car. When I do my buddy's car, the bolt doesn't budge at all. (It's never been off, EVER!) His water pump leaks so we need to get it done.
We only have hand tools. But a 500lb impact will do it? Okay, I can proabably get the bolt loose at a shop then...
Old Nov 4, 2003 | 12:50 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
air tools... i'm not starting my next project without 'em... i'm paid my dues to the hand tool gods.
Project EVA - The Track Package
Project EVA
Old Nov 4, 2003 | 12:55 PM
ManTiS's Avatar
ManTiS
NinJA
Yea, I hear ya, man h:
