Kyb Agx Installation ... help
Old Nov 1, 2003 | 12:26 PM
irod87's Avatar
irod87
Default Kyb Agx Installation ... help
so im fixing to order some kyb agx shocks and struts for 330 what is involved in installing these?Will they work with my already installed nuespeed drop springs or do I have to get new ones?
Old Nov 1, 2003 | 12:31 PM
99 ej's Avatar
99 ej
2 Liters
i dont know the drop of the Neuspeeds, but KYB recommends a drop of about 1.5 inches or less. I have them on my EK with Eibach Pro-kits and the drop is about 1.7 and they are fine. I say if the drop is under 2 inches you should be fine
Old Nov 1, 2003 | 12:37 PM
agent87's Avatar
agent87
Need zzzzz's
They will work perfectly fine. As for install, do a search on here and tell us if you can't find anything. I know there have been several writeups (including a simple one written by me ) Also check www.c-speedracing.com. If you still need a better idea, I can write it out for you again...but I think you'll find what you need on c-speed and searching. Good luck.
Old Nov 1, 2003 | 08:56 PM
irod87's Avatar
irod87
anyone else?I could use the input before I go ahead with the purchase tonight
Old Nov 1, 2003 | 08:58 PM
S2Kev's Avatar
S2Kev
If you can turn a bolt it's easy. Just purchase them and we'll help you out.
Old Nov 1, 2003 | 09:22 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
1. the kyb agx's are not struts and shocks....just struts
2. depends on if you have sport or race neuspeed springs, race are about 2.25-2.5 drop and sport are somewhere around 1.8 i do believe so if you have the race you'd be pushing it
3. i just installed some kyb agx's on my car it's super easy.....undoing 2-5 bolts on the front set and like 2-3 bolts on the rear set
Old Nov 1, 2003 | 09:23 PM
irod87's Avatar
irod87
alright cool
Old Nov 1, 2003 | 09:42 PM
S2Kev's Avatar
S2Kev
This has been bothering me lately so get this right.
They're actually called a shock in a Double Wishbone suspension.
A strut is what a Macpherson strut suspension has. The basic difference with the strut is that it rotates as you steer the wheels.
There is a bearing in the strut mount which sits on the top of the strut. Also a Macpherson strut doesn't have a upper control arm.
A strut and shock have the same job, they're often called dampers. They dampen shocks that the springs absorb, hence the name damper.
From the looks of cars with neuspeed sports and neuspeed race, it seems they have similar drops. The neuspeed race probably sits lower but it's not that much of a difference from neuspeed sports.
Old Nov 1, 2003 | 09:47 PM
irod87's Avatar
irod87
i got the nuespeed race.2.5 front 2.0 back but my back sits lower than my front does.and the kyb agx that im buying says is comes with struts and shocks?
Old Nov 1, 2003 | 09:48 PM
irod87's Avatar
irod87
2.25 front
