? about projectors
Originally posted by VTEC
Yes, it uses 9006 and 9005...I'm talking about the depth of the housing when I say a 9006 (very long compared to H3) won't fit an H3 housing.
The pic I posted is the 9006/9005 Civic headlight. Like I said before, it doesn't look as clean as the H3 projectors. I'm not sure on lighting performance...the 9005 reflector looks like it didn't have any though into the design.
If you still want a 9006/9005 Civic headlight, go to nopi.com.
How can I tell what type of bulb the projector uses? Most places don't list bulb sizes and I can't really tell a difference from the pictures. Can someone who knows tell me which projectors at Nopi are 9005/9006? Also, on a projector that uses 9005/9006 bulbs, which would be the low beam, and which the high beam?
Here's my input.
Whatever bulb inside the projector really doesn't matter, it's the projector design itself. I've used every bulb on the market in my H3 housing projectors, the CLEAR ones and the "ION" BLUE ones. The light output on the BLUE is really bad. The CLEAR produces somewhat better light. I given up on the candle glow-type light and retro-fitted real Phillips HID in them. The light is brighter, but it's the actual design of the reflectors within the glass, the housing, and inside. The beam pattern is too scattered. HID Bulbs, D2-S's only come in one size, regardless of your housing specifics, the difference between H3 and H4 HID bulbs is just the base where it is mounted in the housing. Lighting will not change. So this is my reasoning behind no dramatic difference between higher wattage bulbs, bigger 9006 bulbs, etc. It has to do with the cheaply made elipsoid sphere. It is significantly different to those glass spheres on Integras, S4's, and BMW's.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Originally posted by MaxBoosT
Here's my input.
Here's my input.
I think 9006 projectors are physically larger in both length and diameter than H3 projectors, but sometimes you still can't tell just from pictures.
Originally posted by derf
my 'blue ion' projectors project a yellower beam than I wanted. its OKAY tho, i'm using showoff 'krypton' bulbs and its shining pretty stock color ish....
my projectors are good! a few blemishes but I def. didn't pay much for them. (139 for halo)
beamwise is good imo, i think they're basically the same as the other projectors, but you get the rings.... high beams work well too in my opinion. i need to reaim them cuz they are a little high now so I assume it will be even better soon...
of course i never owned or know anyone else who owns projectors so I can never compare. i'm happy
ironscepter
06+ Civic/CSX
Feb 3, 2008 05:44 PM
whiteblazer01
Accord
15
Sep 8, 2004 08:39 AM
switzltek
2
Jun 2, 2003 10:14 PM
