Nos in a y7
Old Oct 23, 2003 | 09:25 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
Default Nos in a y7
sorry i tried searching but my browser sucks.
my friend is gonna be running a NOS 50 shot. he got zex plugs and a ignition setup coming in. do you recommend he retard his cam or timing? what else does he need?
Old Oct 23, 2003 | 09:28 AM
Smurf's Avatar
Smurf
Dancing Banana Driver
nothing it will be find for a long while. Just dont go hog wild on it.
Old Oct 23, 2003 | 09:52 AM
oc_civic's Avatar
oc_civic
mcc racing
hes fine....
Old Oct 23, 2003 | 02:28 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
Originally posted by oc_civic
hes fine....
:werd: when running a 50 shot,..you dont have to mess with the timing at all
Old Oct 23, 2003 | 02:30 PM
Smurf's Avatar
Smurf
or a 55 if you want to be a dare devil! haha....
Old Oct 23, 2003 | 02:32 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
:chuckles: okay okay,..just to into a little bit more detail,..if you run a 75 shot and up,...you might want to adjust the timing
Old Oct 23, 2003 | 02:34 PM
Smurf's Avatar
Smurf
however, dont run a 75 shot if you plan on using it a lot on other note
Old Oct 23, 2003 | 04:47 PM
NeverBX's Avatar
NeverBX
what if his cam is already advanced 3 degrees would there be any downfalls to running NOS with an advanced cam?
Old Oct 24, 2003 | 09:10 AM
oc_civic's Avatar
oc_civic
mcc racing
doesn't cam timing indirectly advance ignition timing? if that is the case then yes, thats bad... overly advaned ignition will cause detonation.. does your friend have an aftermarket cam springs and retainers? because that is the only reason i could see to push the powerband up higher?
Old Oct 24, 2003 | 05:52 PM
YeaItsAFourDoor's Avatar
YeaItsAFourDoor
..::-Free your mind-::..
Tell him to retard it back.
