Head Removal help.
Old Oct 20, 2003 | 10:50 AM
Redcivic's Avatar
Redcivic
One of the original OG's
Default Head Removal help.
Okay, so I need to have my old D16Z6 head rebuilt for duty on the brand new D16Z6 block. Can anyone give me the simple steps for removing the head and can you tell me what needs to be removed for a rebuild or do I just give the shop everything. From my manual I see that the cam and valve assembly needs to come off. Do I then take those parts to th shop too? Thanks, I don't like the directions I have in the Haynes.
Old Oct 21, 2003 | 07:03 AM
Redcivic's Avatar
Redcivic
okay.
Old Oct 21, 2003 | 07:11 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Head removal:
remove crank pulley (belts need to be removed first)
remove valve cover
remove timing belt covers
mark the timing belt and cams/crank sprocket if you're going to reuse the belt
loosen timing belt tensioner
remove timing belt
drain coolant
remove exhaust manifold
remove intake manifold
remove head studs
take off all coolant hoses that go to head
unplug all sensors that go to head
That should be it
I'd leave the whole head together when you take it down there. The shop I took it to wanted it all in one piece so they knew what goes where.
hih
Old Oct 21, 2003 | 10:56 PM
dantastic's Avatar
dantastic
cx power!
no need to remove the timing belt to get the head off... i didnt to change my head gasket.
Old Oct 22, 2003 | 05:36 AM
westcoaststyle
Did you remove the cam then?
Old Oct 28, 2003 | 06:42 AM
Redcivic's Avatar
Redcivic
So the cam can stay in. When I looked at it I thought I would'nt be able to get soem of the head bolts out without removing the valve assembly.
Old Oct 28, 2003 | 06:44 AM
westcoaststyle
just take off what you have to and leave on what can stay :db:
You've worked on cars before, you know what it takes.
Old Oct 28, 2003 | 07:21 AM
Jafro's Avatar
Jafro
I'm made of meat!
What I'll be doing today...
1. Remove fuel rail
2. Disconnect throttle body
3. Smash valve cover and timing cover with a hammer
4. Cut timing belt, coolant/vacuum hoses, and wires with Tin Snips
5. Pull the head bolts
6. Remove head
7. Check out
Something tells me you'll want to be more careful with your own car.
