Idle at 2,500rpm's wtf?
Old Oct 20, 2003 | 06:45 AM
Redcivic's Avatar
Redcivic
One of the original OG's
Default Idle at 2,500rpm's wtf?
Okay so I was getting a CEL for TPS qand my car was idleing like shit. So I bought a new TPS off ebay and commenced to replacing it. Then I got no CEL but shitty idle. So I take off the IAC valve and it looks like shit. So I grab the one off the B16A sitting in my garage and slap it on. Still idling like shit so I call a friend and he comes by with a hnew throttle body assembly for his B16A that he has not had a chance to install. We install the new throttle body (new TPS, MAP, etc.) and the car starts up and idles at like 2,500rpm's. No more crappy idle but it's idleing way too high. And when it warms up, it only drops to like 1,500rpm's. The car runs great, no loss of power and seems even smoother before but that fats idle tells me there is something else wrong but there are no CEL's. I tried resetting the eCU but it's still the same. BTW, I'm using a chipped p28. I have a 88-91 B16A ECU, should I try that and see what happens?
Old Oct 20, 2003 | 10:06 AM
Civic2Scooby's Avatar
Civic2Scooby
did you try adjusting your idle settings via the throttle cable adjustments?
Old Oct 20, 2003 | 10:32 AM
Sasebonian's Avatar
Sasebonian
'Till All R one!!
Also have you tried adjusting the intake screw?
Old Oct 20, 2003 | 10:45 AM
Redcivic's Avatar
Redcivic
yes, I tried the screw and the cable is adjusted correctly with 3/8 to 1/2" deflection in the cable. Adjusting the screw just makes it idle faster.
Old Oct 20, 2003 | 12:10 PM
ManTiS's Avatar
ManTiS
NinJA
I bet it's the throttle body gasket not sealing right. Spray some 'Starter Fluid' around the gasket.
Old Oct 20, 2003 | 12:43 PM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Not to bust in on your thread bro but I had a related question....what is a 93 ex auto. suppose to idle at?
Old Oct 20, 2003 | 12:56 PM
ManTiS's Avatar
ManTiS
NinJA
Sometimes it's on the underside of the hood
Old Oct 20, 2003 | 01:53 PM
Sasebonian's Avatar
Sasebonian
'Till All R one!!
I believe it's supposed to be between 600-700rpms
Old Oct 20, 2003 | 02:36 PM
theguy386's Avatar
theguy386
I am tehguy... OH YEAH!!
i have a 95 ex that idles at around 600 RPM's
Old Oct 20, 2003 | 02:45 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Sounds like a vacuum leak like said above. Considering replacing the throttle body gasket.
