Idle at 2,500rpm's wtf?
Old Oct 20, 2003 | 06:56 PM
jonjon's Avatar
jonjon
2000 Auto Ex here...300-400 (MSD produced) pretty cool
Old Oct 20, 2003 | 07:59 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I have to agree with the vacuum leak theory. That's exactly what happened when the vacuum line kept popping off of my FPR.
Old Oct 20, 2003 | 08:24 PM
Wharbone's Avatar
Wharbone
Mine idles around 600-700, but sometimes it drops way down, like really low. What could be causing that?
Old Oct 20, 2003 | 08:31 PM
westcoaststyle
If you have PS, the pump can burden the motor when you turn the wheel and it will drop your idle. It could also be bubbles in the coolant (from what I understand).
Old Oct 20, 2003 | 09:05 PM
Wharbone's Avatar
Wharbone
I do have PS. Could it be anything else like a bad fuel pump or clogged fuel filter? It goes really low sometimes (almost the very bottom of the tach) but it hasn't stalled.
Old Oct 20, 2003 | 11:46 PM
drew935's Avatar
drew935
Laguna Seca circuit
it's your fast idle valve under your throttle body where the two coolant lines connect to. use an 8mm wrench to open the cover on the back side and turn the valve in a little while the car is running. HAd the same problem before
Old Oct 21, 2003 | 06:58 AM
Redcivic's Avatar
Redcivic
One of the original OG's
Okay, no one had a throttle body gasket and the dealer was closed so I made my own :thumbup: Must be that. Seems like it sealed pretty good though. That's what i get for riggin it up like a dumbass. I thought a vacuum leak would make it idle crazy, not a steady high idle.
