3-5 Angle Valve Job?
Old Oct 13, 2003 | 06:49 PM
DanM's Avatar
DanM
Originally posted by westcoaststyle
I have a 3 angle on my valves. Couldn't tell you if it made a difference cause I did it all when I did my build. Supposed to be much better for valve seal though.
Agreed. A blown application like yours is one of the few where I would definitely consider a 3-grind, and in this case, it's nothing to do with flow around the valves, but because it should create a better seal if the seats are properly ground too. Even or someone running 11lbs of boost like you, I still say 5-angle is way overkill. May as well throw your money away. Or give it to meeeee.
Old Oct 13, 2003 | 06:50 PM
qtiger's Avatar
qtiger
I would suggest sticking to 3 angles on Honda heads. There isn't much material and a 5 angle tends to wear faster.
Old Oct 14, 2003 | 04:41 AM
wilsel's Avatar
wilsel
Alright thanks for the replies. Learned something new today.:thumbup:
Old Oct 14, 2003 | 05:18 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
'bout time!
Old Oct 14, 2003 | 08:27 AM
incublinkus's Avatar
incublinkus
JDM Fan Boy
yeah, I always heard 5 angle valve jobs wear a lot quicker.
