vtec???
Old Oct 9, 2003 | 06:04 AM
KaneGrant's Avatar
KaneGrant
Default vtec???
when an engine has vtec what does it mean? does it have something to do with the cams at a higher rpm?
Old Oct 9, 2003 | 06:07 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
http://auto.howstuffworks.com/question229.htm
VTEC (which stands for Variable Valve Timing and Lift Electronic Control) is an electronic and mechanical system in some Honda engines that allows the engine to effectively have multiple camshafts. As the engine moves into different rpm ranges, the engine's computer can activate alternate lobes on the camshaft and change the cam's timing. In this way, the engine gets the best features of low-speed and high-speed camshafts in the same engine. Several of the links below go into the actual mechanics of the VTEC system if you are interested.
Old Oct 9, 2003 | 06:23 AM
KaneGrant's Avatar
KaneGrant
thanks dude that was pretty insightfull, i kind of had that impression about the vtec but i didnt realize a pin joined the valves together. thanx
Old Oct 9, 2003 | 06:26 AM
westcoaststyle
Ya, it's a pretty cool setup. A lot of moving parts coming alive in a specific balance. Glad I could help out.
Old Oct 9, 2003 | 08:41 AM
SRT_Andy's Avatar
SRT_Andy
The Honda engineers really outdid themselves when they thought up VTEC. Other car manufacturers are creating their own types of VTEC now. Damn losers...
Old Oct 9, 2003 | 10:58 AM
veen's Avatar
veen
Señor Member
:werd: toyota has "vvti" bmw has "vanos"(a little more advanced tho) and theres others
Old Oct 9, 2003 | 04:25 PM
gsr92hatch's Avatar
gsr92hatch
do u think the VTEC in the B18c (gsr) is worth the xtra grand that hmotorsonline wants over the B18b (ls)??
Old Oct 9, 2003 | 04:28 PM
westcoaststyle
Depends on what you want to do with the motor. VTEC does make more power, but I've always been told that the nonVTEC motors are better for FI.
Don't know how true that is. :dunno:
I'm happy with my B18C1 and enjoy VTEC.
Old Oct 9, 2003 | 04:29 PM
EKHatchRacer's Avatar
EKHatchRacer
the gsr motor has more power than an ls. ls doesnt have vtec but it is torqy. i would rather have a gsr cause you could easily convert it to a b18c5 cause the blocks are the same
Old Oct 9, 2003 | 04:32 PM
westcoaststyle
again, depends on the goal of the owner. putting some C5 cams, springs, retainers, and some C5 pistons will give you a C5, but you wouldn't want that for FI.
You should decide on what you want the motor to do and what you plan to do to it before making a purchase. jmo
