plus sizing the tires
Old Jan 18, 2007 | 08:08 AM
Buyimports2's Avatar
Buyimports2
Originally Posted by ErichPryde
buyimports- to answer your question I drive a 2006 civic si, and I'm not really concerned with increasing my contact patch that much, I just wanted to know, more or less, if a 245/40 would fit on a 17 inch wheel without causing any problems.
I think this was already answered, but I'm pretty sure a Honda Civic is not made for tires as wide as 245, so rubbing is pretty likely. It may also look bad without a wide body kit because there won't be any room for the tire to go but out. You will probably also need rims with a different offset.
Old Jan 18, 2007 | 11:47 AM
flyromeo3's Avatar
flyromeo3
a 245/40 tire on a 17x7 in wheel WILL NOT FIT.
THE TIRE IS TO WIDE AND THE RIM WILL NOT ACCOMODATE IT.
The most you can fit on that rim is 235 ( and I think thats calling it close )
If you want to put 245 width tires you will need to get a 17 x 7.5 or 8 rim.
( doubt will fit on 7.5 )
Theres no easier way to explain this unless I whip out a ruler and physically show you.
dont go by ohh this tire is 20 inches wide so it should fit on this 20 inch rim.
Now the reason you will go down two sizes on the profile is because your trying to fit a wider tire than the rim can sort of handle. So to compensate for the extra width you gotta lower the profile. That way the tire wont buldge out on either size of the rim.
go with 225..and save yourself some headaches.
245 will possibly rubb since your civic's wheel well isnt designed for that.
Old Jan 18, 2007 | 11:52 AM
flyromeo3's Avatar
flyromeo3
DEFINITELY LOOK AT THIS LINK
It will explain all that you need to know
http://www.discountedwheelwarehouse....ment_Guide.cfm
Old Dec 12, 2007 | 05:08 PM
ErichPryde's Avatar
ErichPryde
I know this is a dead thread.... but I felt like adding that WITH the correct size wheel, a 245 mm tire will fit in the wheel well without rubbing anything.
It will not fit the stock 17X7 wheel, but there won't be any rubbing issues.
I didn't put a tire this size on my car, I stuck with the stock 215s.
thanks to Greg with Redshift motorsports for this information.
Old Dec 13, 2007 | 09:58 AM
cpvdh's Avatar
cpvdh
it should be mentioned that by correct size wheel you dont mean just a wider wheel but also one with the correct offset so that no rubbing will occur
good choice sticking with the 215, i wouldnt have gone any larger than 225 unless changing suspension components and wheels, and you would lose mpg and add road noise even doing that
what kind of tires and how are you liking them?
i think there are a few si owners on here looking for new tires soon so a little review im sure would be loved
