97 Civic Headlights - HELP ME
Old 03-13-2006, 10:05 PM
N76
N76's Avatar
Default 97 Civic Headlights - HELP ME
I am trying to change my 97 civic EX's driver side headlight. The manual says you should pull out the cylinder for the power steering fluid. Yet I can not move it much because the tubes it has attached won't let it move. I cannot get my hand between the headlight and power steering fluid cylinder to get the bulb out. Do I need to unhook the power steering fluid cylinder and remove it all the way to get the bulb out? Anyone know?
Thanks
Old 03-15-2006, 09:54 AM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
https://www.honda-acura.net/forums/s...d.php?t=177020
https://www.honda-acura.net/forums/s...d.php?t=228136
Old 03-29-2008, 09:35 PM
goldex420
goldex420's Avatar
ha
Old 04-14-2008, 12:18 PM
mikecivic
mikecivic's Avatar
Default headlight
If it is similar to my 2001 civic ex, the ps fluid reservoir slides straight back off the pump body, I didn't have to undo any lines. with the reservoir out of the way and you can get to the back of the bulb easily.
Thanks
