Is 5W30 oil suitable for winter for my accordl?
Is 5W30 oil suitable for winter for my accord 4ycl 93model? the car shop megastore in Toronto, canada, Canadian tire recomend I use that oil. I put in 4litres of that oil for engine. What oil should I put in the engine for warm season?
Use whatever is recommended in your owners manual. 5W30 should be suitable for just about anything. I use 5W20 in my Element all year round. Its thin enough for cold weather but protective enough for hot weather and it is what is recommended by Honda.
Older accords didn't have the recommended oil type imprinted on the oil caps... check your owner's manual. I'm sure it would recommend 5W30 for winter months and 10W30 for summer. Newer honda's require 5W20 for all seasons.
I am about to change my oil at the end of the month and for the second time I will be using 5W20 for older hondas.
I can tell you I now get 33mpg in normal traffic and normal driving in nyc area and my car warms up faster ever since I switch from mobil1 to honda oil.
lots and lots of fail
1 Post
Originally Posted by strykernyc
Also they have 5W20 for older honda check with your dealer.
Why does your car warm up faster? It's probably because you have more resistance inside your engine because the 'Honda' oil doesn't lubricate as well as the Mobil1. Think about it...more resistance=more mechanical energy lost=more heat produced :happysad:
I see what you are saying and it does make sense. but if I go back to using mobil then I should expect my engine to be more protected but less gas miles?
usually I follow what the dealer recommends but I dont want to sacrifice the engine so I can just have better miles per gallon.
what about all the new cars using 5W20?
1 Post
