need help with rotor.
Old 11-10-2004, 06:29 PM
sliptip
sliptip's Avatar
Default need help with rotor.
hey fellow peeps.
im trying to do a tuneup on my 95 teg. got all the wires, sparkplugs and distributor cap done. the only problem is getting the rotor off. i unsrewed it but that damn thing just wont pry off. any advice ???
Old 11-10-2004, 07:07 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
If you unscrewed it, it should come off. Pull as hard as you can and it should come off. I changed my rotor once and I had to pry it off with a screwdriver and pliers. Keep trying.
Old 11-10-2004, 07:18 PM
sliptip
sliptip's Avatar
thanks for the advice, but it seems i might crack the plastic off or something else knowing my luck. could i really mess up my rotor by prying the mother off?
Old 11-11-2004, 01:36 AM
Kai
Rotorphile.
Kai's Avatar
It should pull right off, that's all I can say.
Old 11-11-2004, 07:52 AM
Tobra
Tobra's Avatar
If you are not pulling it straight off it can sort of get tight, I wiggled mine a bit and it slid right off
Old 11-11-2004, 08:36 AM
sliptip
sliptip's Avatar
well ill try later today with some vicegrips... thanks for the feedback fellas.
Old 11-11-2004, 12:45 PM
the1bolton
the1bolton's Avatar
when I was replacing my rotors I had to give a good smack with a hammer. A very very very very small amount of rust had managed to practically unite the hubs and rotors. (I think 1/4 came off without the hammer, which I just used my fist to hit it with). I know it sounds kinda archaic, but hey, they were warped beyond your wildest dreams and I was just careful not to damage anything else it was connected to or near.
Old 11-11-2004, 04:15 PM
dubcac
I
dubcac's Avatar
He was talking about the rotor for the distributor, not brake rotor.
Old 11-12-2004, 10:32 AM
IrishBrewer
IrishBrewer's Avatar
I broke mine getting it off because I didn't know there was a screw through the side of it holding it on. I noticed it after I broke the old one and after I got the screw out (which was kind of a pain) the rest of the rotor came off fine.
Old 11-12-2004, 08:49 PM
sliptip
sliptip's Avatar
wow i finally took the rotor off.. yeeeeehaaaa.
