Should My Accord Temp. Control System Blow The Fan On High Before There Is Heat?
Old 12-04-2003, 01:40 PM
pmilnes
pmilnes's Avatar
Default Should My Accord Temp. Control System Blow The Fan On High Before There Is Heat?
re-posted to hopefully be easier to understand...
Hello,
I have a 1999 Accord with a temp. control system -
When I get into the car in the winter and the temp is set to a warmer temperature, and I leave the fan on 'auto', it immediately starts blowing cold air WITHOUT waiting for the heat to come.
In my wife's Sienna van, the fan speed waits until there is heat. Our 96 Jeep Cherokee did the same thing - the fan did not turn onto high until there was heat.
Is this how a Honda is supposed to work, or is there a problem?
Thanks!
Old 12-04-2003, 03:08 PM
MrChad
THE RED 6th GEN Coupe
MrChad's Avatar
This is normal.
Old 12-07-2003, 08:39 PM
showgunz
showgunz's Avatar
Yeah, the Honda auto climate system isn't as intelligent as your wife's Sienna to do that. Whenever you turn on the heat and you haven't turned on the heat earlier, you'll get cold air coming out first. So ideally, the Honda auto climate system should wait to get warmed up first, but it doesn't.
Old 12-07-2003, 10:41 PM
Eryeal
Eryeal's Avatar
I don't think that's true. In my 6th gen as well as my 7th gen, the heat would/will always wait until the engine is a bit warmed up before coming on .. The other thing I noticed (with the 7th gen, not the 6th), is that before the engine is completely warmed up, it will blow most of the air full blast out of the defrost vents .. then once it gets really warmed up, it switches to the floor vents .. Just an interesting tidbit.
--Brian
Old 12-07-2003, 11:33 PM
Nightshade
un-Touch'd krew
Nightshade's Avatar
Brick under seat....works wonders
