this one is way out there
oaky i was just thinking that maybe if u had a fully built motor and u turboed it, but what if you could have a turbo and a supercharger bolted on also or would that not be able to work. there would be a shit load of power going to the ground
On permanent hiatus
It would work and I have seen it done.
Not only would it be a bitch to tune, but the intercooler would be pointless because the air would just be heated up again when it is compressed by the supercharger. Unless it is for show, there is no reason for any such setup.
On permanent hiatus
Originally Posted by red94teg
technically, a turbo is a supercharger. h:
Yes, they both compress air, but they do it in completely different ways.
Relevance is irrelevant
I don't think there is any practical use for both but it seems to me like a small SC could feed the turbine whenever the exhaust isn't doing it for a good result. Obviously if it were some wild end all to boosted applications someone would have thought of it by now since both were put into mass production more than 50 years ago
FuK JDM
I remember seeing this done in an article and thinking to myself WTF...its deffinately possible but i don't see the point unless you go with "bluetwo's" theory
www.ufc.com
Originally Posted by Däs Schmoo
How do you figure?
On permanent hiatus
Originally Posted by centerforce99
I think maybe he means "forced induction" in general and yeah, I can see that "technically" they serve the same purpose through different manners. A SC is belt driven and blows air whereas a turbo is exhaust driven and recycles air back in to make power. "Technically" they are doing the same thing when you generalize air being forced into the motor to make more power. I want to hear more about that superturbocharged car though. How did that run?
The superturbocharged car was nuts. I think it was a Miata that I saw and it could not get traction in any gear. It definitely didn't look streetable, but the setup looked pretty awesome.
