cleaned throttle body valve and shifting lags
Old 11-30-2009, 12:43 PM
Taccord6
Taccord6's Avatar
Default cleaned throttle body valve and shifting lags
can the throttle body valve cause AT shifting problems? i cleaned the throttle body valve with tbv cleaner and now my AT lags when shifting b/w 2nd and 3rd. it's more prominent when i'm acclerating harder. any ideas?
Old 12-10-2009, 11:27 AM
ricardo95
ricardo95's Avatar
yeah man, u probably got dirt in there or into a sensor.
In my research b4 performing the clean I read that happens (erratic shifting) when u clean the TB. Take the air filter tube. Use map sensor cleaner or alcohol to clean it out. Then some injector cleaner in a tube and funnel while the car is running. I may unclog the injectors. I used a bit of seafoam. But fuel injector cleaner is good as well. good luck.
Old 12-11-2009, 08:54 PM
Taccord6
Taccord6's Avatar
Thanks
Old 12-12-2009, 11:34 AM
cruzalekz
cruzalekz's Avatar
keep driving the car, since you cleaned the throttle body, the pcm needs to relearn what you just cleaned.
