Check Engine Code List
Old Jan 28, 2004 | 06:21 AM
livelyjay's Avatar
livelyjay
Default Check Engine Code List
Does anyone have a link to any site or thread that has a listing of engine codes for a 1997 Accord? Thanks.
Old Jan 28, 2004 | 02:24 PM
carta79's Avatar
carta79
Life after death
Trouble code-----------------------Circuit or system
Code 0------------------------------ Faulty ECM
Code 1-------------------------------Oxygen Sensor
Code 3-------------------------------Manifold Absolute Pressure switch
Code 4-------------------------------Crankshaft Position sensor
Code 6-------------------------------Engine Coolant Temperature sensor
Code 7-------------------------------Throttle position sensor
Code 8-------------------------------Top Dead Center position sensor
Code 9------------------------------Cylinder position sensor
Code 10-----------------------------Intake Air Temperature sensor
Code 12-----------------------------EGR valve lift sensor
Code 13-----------------------------Barometric Pressure sensor
Code 14-----------------------------Idle Air Control valve
Code 15-----------------------------Ignition output sensor
Code 16-----------------------------Fuel Injector
Code 17-----------------------------Vehicle speed sensor
Code 20-----------------------------Electronic load detector
Code 21-----------------------------Variable Valve Timing solenoid valve
Code 22-----------------------------Variable Valve Timing pressure switch
Code 30-----------------------------A/T FI signal A (automatic transaxle)
Code 31-----------------------------A/T FI signal B (automatic transaxle)
Code 41-----------------------------Oxygen sensor heater
Code 43-----------------------------Fuel supply system
Code 61-----------------------------Oxygen sensor
Code 63-----------------------------Oxygen sensor
Code 65-----------------------------Oxygen sensor
Code 67-----------------------------Catalytic converter
Code 70-----------------------------Automatic transaxle
Codes 71 through 76-------------Cylinder missfire
Code 80-----------------------------EGR system
Code 86-----------------------------Engine Coolant Temperature sensor
Code 92-----------------------------Evaporative emissions system
Are you asking for "Engine codes" or "Check engine light codes".
Momobile
Accord
3
Sep 5, 2003 06:44 PM
laosb904
Prelude
2
Jul 26, 2003 11:11 AM
mccullpl
Prelude
Jan 6, 2003 03:12 AM
epoxy
Prelude
7
Nov 25, 2002 12:25 PM
jaje
News & Rumors Archives
Jul 11, 2002 08:01 AM
