Top of shock tower.. is this good enough?
Old 12-03-2002, 12:50 PM
FLiPKiD
FLiPKiD's Avatar
Default Top of shock tower.. is this good enough?
is this good enough? i cant get the nut any tighter
Old 12-03-2002, 12:56 PM
tokyoracer
got JDM milk???
tokyoracer's Avatar
Default Re: Top of shock tower.. is this good enough?
if you can't get it any tighter, then that's as far as it goes. that's is assuming that you clamped the top while wrenching on the nut.
Old 12-03-2002, 01:40 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
the other way to do it is to use some vice grips and hold the actual rod from the other end. Basically jack the car up, and grab it between the coils of the spring with the vice grips, and try tightening it more.
Old 12-03-2002, 01:49 PM
FLiPKiD
FLiPKiD's Avatar
cool.. ill try that
Old 12-03-2002, 01:50 PM
ManTiS
NinJA
ManTiS's Avatar
That don't look safe.
Old 12-03-2002, 05:30 PM
HatchVX
Driving a Turbo 2L Terror
HatchVX's Avatar
Wont the mess up the rod? I would just keep at holding the top and then tighting the nut.
Old 12-03-2002, 05:34 PM
FLiPKiD
FLiPKiD's Avatar
does anyone have other opinions about holding the rod to tighten it? what Bakeoff suggested
Old 12-03-2002, 05:37 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
If you do this, make sure you do it as high as you can on the rod or you'll mess it up. Forgot to mention that.
Old 12-04-2002, 06:34 AM
FLiPKiD
FLiPKiD's Avatar
i tried getting to the rod to tighten it, but the dust cover is in the way. i couldnt tighten it anymore..
The nut is so tight, what would be the chances of it popping off?
Old 12-04-2002, 06:37 AM
crucial Si
Banned
crucial Si's Avatar
bakeoff.. that will mess up the rod...
if you gonna do it that way, get a piece of cardboard and stick it inbetween the rod and the vicegrips. you wont mess up the rod that way.
