92 eg track ready!!! [SoCal]
well its a 92 civic hatch... black with bronze rota c8 with new falken 514s not the best tire but OK.... so here is a fast run down of what is on my eg. spoon mirrors ,spoon style front lip also have rear not on the car,carbon hood ,carbon duck bill wing ,jdm window visors ,flat plat for antenna.....suspension function forum (fully adjustable) i believe they are the number twos,skunk 2 front upper A-arms (camber adjusters),Megan front lower h-brace(red) rear omni power camber adjusters, rear toe adjusters by wicked(gold),omni rear lower control arms (polished),A.S.R rear enforcement brace (polished),brand new suspension techniques (green) sway bars just put the rear on haven't had the time to put on the front yet (19mm rear 23mm front),del sol rear trailing arms,drilled and slotted rotors (brembo rotors)all four,steel breaded lines still in box(sumit racing dated 11/08)... six point roll Gage roll bar,door bars,harness bar, x-ed in the back also tower to tower in the rear...this chassi does carry a salvage title but is 100% striaght(only rear ended)and everything has been repaired ,stock seats (have two tenzo with rails kind of beat up but not in car)stock seats,sparco harness(driver only), auto meter big tack, v-afc(v-tec air, fuel, controller) ,skunk 2 short shifter (not on the car) skunk 2 balanced shift knob, jdm sun visors,jdm center console, NR-G quick release hub with six inch extension, mugen wheel, b16 block 1.7 gsr head,hass port mounts,skunk two stage two cams manly valves spring retainers lifters ext... cp pistons,eagle rods,knife edge crank, this motor is balanced and blue printed,WITH ONLY 5K MILES ON THIS MOTOR,chipped ECU BUILT AND TUNED BY WORLD RECORD HOLDER/TUNER BUBBA FROM DOIT DYNO,97 gsr tranny,ACT 6 PUCK CLUTCH,AEM LIGHT FLYWHEEL,CTR PULLEYS,AEM FUEL RAIL ,INJECTORS,AEM cold air intake,valve cover blow bye reservoir,drive master cylinder brace,cx racing radiator 10 inch fan,shocker msd, 2 3/4 inch piping header back, rs-r muffler,e-mail me timallen61@hotmail.com from $6000 down to $5000 must sell !!!!!!!! obo all reasonable offers considered!!!!!!
