FT: 1989 240sx in NY State
hey quick question about the fender, if i got a fender from a junkyard or a s13 silvia front end, would it mount up correctly and not be bent or warped? i guess i want to know if the fender is replaced will the body be 100%
Yes, you should be fine. I just pounded out the dent a few minutes ago.
I had the fender off and everything is good underneath.
The only reason it's dented in the first place is because while I had it off the road at the beginning of this past winter, some ice got in behind the fender and bent it into the path of the door, when I opened the door, it hit the fender and bent it. I don't think this car has ever been hit.
