Which bushings to replace.
Old Aug 22, 2003 | 01:18 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
you just need the knuckles for the brakes, but if youre going all out with the bushings, I'd take advantage of all the suspension parts that are off the car.
As far as I know, you can use the front LCAs (in conjunction with the front sway and endlinks) and knuckles, I don't think the front upper CAs are interchangable between EK and DC though. I don't know what you have for a rear sway, but I'd use the DC rear lower CAs so you can use an ITR (or any teg) rear sway...
Just make sure to order the bushing kit for whatever the suspension peices youre using... Although the suspension is interchangable between cars, that doesn't mean the bushing diameters in the susp. pieces themelves are the same...
:edit: you should be able to use the civic shocks with teg LCAs, so don't sweat that.
Old Aug 22, 2003 | 01:48 PM
qtiger's Avatar
qtiger
AFAIK, the EK and DC suspensions are very much different. Supposedly it's just the length of the shock/spring combo that differs.
Old Aug 22, 2003 | 02:55 PM
white_n_slow
it's my D in a B
sorry, I must have had EG on the mind :doh:... done too much suspension/brake crap lately. h:
Old Aug 22, 2003 | 04:51 PM
PHiZ's Avatar
PHiZ
BOOST GOD
I have an EJ, anyways, where does that put me? Same as teh EG?
-PHiZ
Old Aug 23, 2003 | 07:57 PM
qtiger's Avatar
qtiger
-PHiZ
No. Your suspension is different from what I've heard. I have not, however, had them apart and next to each other.
Unbolt a damper assembly (including fork) from your car and hold it up next to the matching assembly on the GSR suspension.
Hey, worst case scenario, keep your current shock/spring combo and just slap it on the GSR suspension.
Old Aug 27, 2003 | 05:24 PM
PHiZ's Avatar
PHiZ
BOOST GOD
I'm trying to piece together everything I need for a civic front, and teg rear, bushing replacment.
I can't use any of the hyperflex/master kits it seems.
I would ideally like to go with ONE vendor for everything, because in the imaginary fairy tale world I live in, I like to think that they designed their upgrades to work as a system, together...
Anyone have any opinions on mixing and matching prothane components and energy suspension components?
-PHiZ
Old Aug 27, 2003 | 06:27 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Call up energy suspension direct, they can piece together a master kit for your setup.
-Harry
AIM: NDcissive
