how does my alignment look?
left front
camber .7
caster .5
toe .01
right front
camber .2
caster .6
toe .02
left rear
camber -.3
toe .05
right rear
camber -.7
toe .03
how does it look? they are all within specs. but i dunno about having the positive camber.
is it possible to request a certain degree at alignment shops? what should i look to get.
i do 98% daily driving.
thanks.
camber .7
caster .5
toe .01
right front
camber .2
caster .6
toe .02
left rear
camber -.3
toe .05
right rear
camber -.7
toe .03
thanks.
Originally posted by WiLL
left front
camber .7
caster .5
toe .01
right front
camber .2
caster .6
toe .02
left rear
camber -.3
toe .05
right rear
camber -.7
toe .03
thanks.
left front
camber .7
caster .5
toe .01
right front
camber .2
caster .6
toe .02
left rear
camber -.3
toe .05
right rear
camber -.7
toe .03
thanks.
Autocross Help Page
Autocross Help Page
I would go for slight negative like -.2 - -.5
since you're mostly on the street
as for the toe... probably get it close to 0 for the front I wouldn't make it too much toe out. for the street.
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
Originally Posted by WiLL
I agree. Dial in as much negative camber front as you can. Don't know if this is doable for a stock car.
For toe I also recommend 0 toe front and rear if this is a daily driver. Turn-in will be quicker. If you can and willing to have some accelerated tire wear I would go with 1/16 toe out front and 0 toe rear.
Autocross Help Page
Autocross Help Page
ok i will call and request a -2 camber for the fronts. and a 0 toe front and back. i hope they wont mind doing it.
i dont know what you meant by stock car. my suspension constist of ground controls on AGXs, and ingalls kit in the front.
thanks for the advice.
When I got my camber done two weeks ago we spent like a whole hour on one side. Because even moving the Skunk2 front camber kit on my car like .5mm was like a whole degree of camber
Autocross Help Page
Autocross Help Page
wow... .5mm for a whole degree. thats pretty dramatic.
with 2 degrees of negative camber, will i run into any excellerated tire wear, i mean REALLY excellerated?
i mean this is strictly for normal, get me to work and school, street driving.
Why would you want 2 degrees negative camber for a street car? I'm running 2.5 negative for the past month and my tires are fine. WHat kills your tire is excessive toe.
Autocross Help Page
Autocross Help Page
