any advice(auto-X)
Old Mar 13, 2003 | 04:11 PM
truesmallblock's Avatar
truesmallblock
Default any advice(auto-X)
my setup now .
91 ef with a b16 (no lsd) no interior
tokico blue struts
sprint springs
eibach front strut bar
tanabe rear strut bar
spoon sports rear lower tie bar
14" del sol vtec rims with 195/60/14 falken azenis(bald in the front)
stock front sway bar
stock bushings
stock clutch
--non auto-x related parts
dc sports cat back
aem short ram
mugen ecu
momo steering wheel
autometer tach
shrothe harness
hasport billet aluminum motor mounts
i have a rear disc brake set up just need the rotors, pads and intallation.
1.) should i buy a lsd first or do the rear disc swap with a aftermarket sway bar first?
2.)who is going to buy me this stuff?
3.)who is going to help me install it? (i'll not help if you want)
4.)what kind of lsd should i go for or what kind of sway bar should i go for.
5.)is it easy to get a front sway bar off(i should do that right)
6.)HI joel!!!
Old Mar 13, 2003 | 05:44 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Well what class are you in with those mods? Looks like D or E mod with the stripped interior and engine swap. You'd be good in SM if you had interior.
Autocross Help Page
Old Mar 15, 2003 | 11:34 PM
truesmallblock
i race in street mod. you don't need an interior for street mod
Old Mar 16, 2003 | 02:18 AM
CivicSiRacer
Yes you do. According to the rules you can only trim pieces that interfere with other mods. Read the rules again.
http://www.moutons.org/sccasolo/Rule..._modified.html
  • The firewall, roof, doors, rear quarter panels, floor pan, trunk lid (if any) or rear hatch (if any) must remain stock. Holes may be drilled to allow attachment of body kits, etc. This specifically allows replacement hoods, fenders, wings, front & rear fascias, side skirts, and fender flares as per Section 14. Body panels may be attached with removeable (e.g., Dzus) fasteners.
  • Except as noted by these rules and the referenced rules, vehicles must be as originally delivered including all road going components such as lights, wipers, interior, heater, etc.
  • Rear passenger seat(s) do(es) not need to be retained.
  • Any minor modification, intended to allow or facilitate any allowed modification, is permitted as long as it does not provide any intrinsic performance benefit in and of itself, does not provide a weight reduction of more than 1 lb., and is not explicitly prohibited elsewhere within these rules. This rule is intended to allow minor notching, bending, clearancing, grinding; the drilling of holes; affixing, relocating, or strengthening of brackets; removal of small parts, and similar operations performed in order to facilitate the installation of allowed parts or modifications. Competitors are strongly cautioned to make the minimum amount of modification required to affix a given part, and not to make unduly tortured interpretations of this rule. Modifications to the firewall in order to allow for increased engine setback, and any modification that changes the location of of a suspension pickup point, are explicitly forbiddden.
Autocross Help Page
Old Mar 16, 2003 | 10:20 PM
truesmallblock
thats rule is for the chassis not the interior peices such as rear seats, carpet, sound proofing, head liner, center console, door panels, sun visors, seat belts, shifter boot, lets see what else have i gotten rid of.............
Old Mar 16, 2003 | 10:28 PM
truesmallblock
i think you are looking for 18.1-h except as noted by these rules and the referenced rules, vehicles must be as originally delivered including all road going components such as lights, wipers, interior, heater, etc. so i do need an interior
Old Mar 16, 2003 | 10:30 PM
truesmallblock
oh there it is in your second section i was reading way too fast the first time
Old Mar 17, 2003 | 05:02 AM
CivicSiRacer
Autocross Help Page
Old Mar 17, 2003 | 05:44 AM
CivicSiRacer
Try this link too:
http://www.sccaforums.com
Autocross Help Page
Old Mar 17, 2003 | 12:39 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I'd go for a LSD, but thats a lot of money.... I got a disk brake conversion, but more for the street than autocross... Nice to have, but it wont help you much on the track (especially when your car is a slow as mine).
Even with just 92 hp, I've felt the need for a limited slip on the autox course... Its a big investment, but a logical step, and since youre already in mod, it shouldn't change your class.
That said, sway bars are a lot cheaper. You might look into crx si swaybars. My friend autocrosses with those on his 89 civic si (when the triumph isn't running--which is pretty often), and they work pretty well for him and are a cheap junk-yard buy.
