how much negative camber is enough?
Old Feb 19, 2003 | 01:00 PM
AwwsChwA's Avatar
AwwsChwA
Default how much negative camber is enough?
For autocrossing, how much camber is a good amount for a 91 CRX Si runnin on 14-inch wheels with Azenis? I know the factory setting is zero camber front and rear, so it can't take much to make the car stick to the corners a little more. I'm thinkin maybe 1.5 degrees front, and 1 degree rear? What do yall think? thanks
Old Feb 19, 2003 | 06:26 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Default Re: how much negative camber is enough?
Well what class do you plan on running? YOu cannot change your camber for stock class.
But for STS i know guys running 2.5 negative front and 1.0-1.5 negative rear.
Autocross Help Page
Old Feb 21, 2003 | 01:26 PM
AwwsChwA's Avatar
AwwsChwA
Default Re: Re: how much negative camber is enough?
I'm running IS3, basically the two-seater version of STS. All the same rules apply.
